Broken ground wire from strut to chassis.
Old 13 Dec 2012, 10:31 pm
edscrz's Avatar
Default Broken ground wire from strut to chassis.
I was getting my tires rotated and they discovered a broken ground wire from chassis to strut. They researched this and found that it is needed to prevent an arc on the wheel bearings which can wear out the bearings. Mechanic was able to splice and wrap the splice. Supposedly this is a common problem. Glad I caught it and got it fixed. Has anyone else had this occur?
edscrz
Old 13 Dec 2012, 10:49 pm
Default Re: Broken ground wire from strut to chassis.
Here ya go, read this:
Front Ground Straps to struts, WHY?
Old 13 Dec 2012, 11:34 pm
edscrz's Avatar
Glad I got it fixed. He didn't have one to replace it, just spliced it, hope it is ok.
edscrz
Old 14 Dec 2012, 08:10 am
As ling as It's there, It's all good! Hello haven't seen you before. But I see you been on here for many years. Just wanted to say hey.
Old 14 Dec 2012, 09:13 am
davea300's Avatar
Noticed mine had degraded and was hanging down when I changed my brake discs last month. Thought it was there to simply help reduce interference on the radio. Glad I kept it, will have to patch it up and refit now. It's so cold here now I don't know when I'll get a chance. How long do you think I could get away without fitting it if I drive the car almost every day?
2005 2.4 PT CRUISER (UK SPEC)
Short ram intake, chrome grill, chrome belt line, drilled/slotted discs, few flames, engine dress up, chrome bits and pieces.
67,000 miles
Ground wire location.... jpcruz Tech & Performance Forum 3 29 May 2012 06:57 pm
Ground wires broken? iridius Tech & Performance Forum 2 10 Apr 2011 08:17 am
Ground wire placement? chuck2112 Tech & Performance Forum 2 01 Mar 2010 07:24 am
Ground wire elmeyer Tech & Performance Forum 2 01 Nov 2009 08:40 pm
Crappy Ground Wire Mean Green General Turbo Discussions 2 31 Dec 2004 09:56 pm
