Changing front seats - Tyre sizes - Engine size
Like Tree2Likes
Old 16 Dec 2012, 08:26 am
Default Changing front seats - Tyre sizes - Engine size
My owned from new 2000 Limited Silver is past it and I have recently bought a 2005 Red Classic with only 14,000 genuine miles on the clock.
I want to swap the nasty velour seats for my nice leather ones. I presume they will fit, and will first try the rear ones, but for the front, can I somehow slide the seats out of their rails or do I need to unbolt them from the floor?
I presume the seat lifter is plug in connection? Any tricks I need to know?
I note the new one has 195 wheels vs 205 on old one. Can I mix on same axles? I presume same studs.
Old one is a 2000-cc engine. New 2429. Are they the same engine bored out, or different?
In general, are 2000 and 2005 close enough to keep the old for spares?
Old 16 Dec 2012, 08:36 am
Default Re: Changing front seats - Tyre sizes - Engine size
plug it in. The wiring is probably already there, although you may have to search for it
studs are the same.
the engines are different
yes they are
12345
Old 16 Dec 2012, 09:05 am
There is/was ONLY 1 engine size for the PT if your talking about the United States. That's 2.4 ltr or the 2429 cc. The only 2000 cc engine was built for the overseas market but since you didn't fill in your profile, we can't see where you are.
As far as the tire size, your asking to mix 195 and 205 on the same axle. I'm not a tire expert but I'd think that was not recommended by any vehicle or tire manufacturer. Now 195's on the front axle and 205's on the rear would certainly work and many owners and vehicles have done that.
Old 16 Dec 2012, 11:25 am
Hi Crewzin & Zamfire
Thanks for prompt responses.
I am indeed in "overseas" - UK. Profile edited to say so - once I worked out how! So is it the same engine less bored out? Looks similar under the bonnet (hood!)
Sorry - I was unclear re tyres/wheels - meant two matching on SAME axle!
So 205 rear 195 front is OK? Other way round not? Is there a reason? Is there a noticeable difference? I'm just wanting to use up tread. The new car is still on its original tyres! And the front ones are low.
Thanks re seats.
Am I right to think cruise control is fitted to engine of the Classic, just not connected up? Could I swap steering wheels? Or do so anyway, as I think Classic is plastic, Ltd leather?
And finally for now - main problem with the old one was overheating - notably when left ticking over. I saw a similar one for sale with the same fault. Is it a known problem?
Old 16 Dec 2012, 12:16 pm
Not sure if the 2.0 is just bored out to get the 2.4, not into internals of the engine block.
Lots of cars come with larger tires on the rear and the only time I've seen larger on the front is when a front wheel drive is racing and they put larger slicks on the front. The 205 is just the next wider size than the 195 so possibly nothing wrong with runnng the 205 in the front.
Thanks re seats.
Some owners found that even the Classic was fitted with the wiring for fog lights, power mirrors, cruise control, rear subwoofer etc., others looked for the wiring and found nothing. All you can do is look to see if you have extra wiring in yours.
I'll say that the main reason that any of the PT overheat is because of the radiator fan. There are two speeds to the motor of the fan and one or the other speed tends to burn out because of the bushes in the motor that wear out prematurely. Check to see if you have both speeds. In mine, the low speed comes on automatically when the A/C is turned on and when the engine heats up, the high speed cuts in.
Old 16 Dec 2012, 01:14 pm
<< I'll say that the main reason that any of the PT overheat is because of the radiator fan. There are two speeds to the motor of the fan and one or the other speed tends to burn out because of the bushes in the motor that wear out prematurely. Check to see if you have both speeds. In mine, the low speed comes on automatically when the A/C is turned on and when the engine heats up, the high speed cuts in. >>
Thanks for that. I never thought of it, and if my garage did they did not mention it!
Old 16 Dec 2012, 02:39 pm
Chrysler 1.8, 2.0 & 2.4 engine - Wikipedia, the free encyclopedia
The 2.0 and 2.4 engines are related, and even share some parts, but there are significant differences. For instance, the 2.0 is an interference engine and the 2.4 is not.
Old 16 Dec 2012, 06:16 pm
I had to look up what "interference engine" meant!
Know the concept; not the term. Always struck me as inherently bad design - but obviously done with reason of better performance/efficiency.
So is the 2.4 any more powerful than the2.0? Or does it just use more fuel? !
Old 16 Dec 2012, 07:16 pm
Not really more powerful. The normally aspirated version used in the Cruiser is rated at 150 hp. The N/A 2.0 is rated at 140hp. Shrug.
Old 16 Dec 2012, 08:22 pm
UptownSport's Avatar
2.0 (DOHC or SOHC) had a very short stroke, same bore.
Interestingly, the ancient 2.2 and 2.5 shared that bore size, too-
Chrysler must've gotten a discount on a that size boring machine ...
2.4, because of long stroke, is very good for torque-
2.0 DOHC is an exceptional engine, and although it uses same head as 2.4 has much different characteristics; it's able to produce same or higher HP but at high RPM.
2.0 SOHC was better matched to automatics or heavier sedans.
Dangerous oversteer will occur if tires are mismatched in a certain way front to back. You may wish to research your particular fitment, but in short you want most traction and most 'responsive' tires in rear, not in front-
Best example of the wrong thing would be highway radials in front, and bias snows rear (tradional RWD)
Changing out seats chintzgirl Interior Accessories Forum 7 09 Dec 2013 04:45 am
Engine sizes nexium General PT Cruiser Discussions 6 17 Dec 2012 08:56 am
Tyre size question! Botok Wheels, Tires, Suspension 5 07 Jul 2012 11:09 pm
Front Dash Speaker sizes valcansa Sound and Security Forum 2 27 Apr 2009 09:36 am
Does changing the tire size affect ABS? blueberrygt Turbo Wheels/Suspension/Handling 1 16 Apr 2004 09:07 pm
