PT 2002 no error code but mis and preignite
Old 18 Dec 2012, 09:09 am
Default PT 2002 no error code but mis and preignite
Good day i have a 2002 pt touring.I have no idea where to look for the fault it shows no error code but misses and preignites at low rpm. Acceleration is slow. If someone could please help please
Old 18 Dec 2012, 11:21 am
Default Re: PT 2002 no error code but mis and preignite
Sounds like you could have an intake leak. Get some spray start (Starting fluid) - when it is idling, spray along seams of intake manifold - if idle smooths out, you have a bad intake gasket.
Old 18 Dec 2012, 01:08 pm
Ray_Dockrey's Avatar
When was the last time you changed the plugs and wires? And if the check engine light is on what are the codes?
is it an error Code or something else saraPT04 Tech & Performance Forum 5 08 Oct 2010 02:46 pm
Error Code bds02pt Tech & Performance Forum 2 29 Jan 2010 03:01 pm
S1 error code??? mtnbktrek Stage Turbo Kits 2 24 Feb 2009 01:42 pm
CPS Error Code smokeydan1 Tech & Performance Forum 16 23 Sep 2008 09:58 pm
2002 Pt error code P0456 chellee Tech & Performance Forum 2 24 Jul 2008 07:56 am
