random shudder
Old 18 Dec 2012, 04:22 pm
edb edb is offline
Default random shudder
My PT 2003 Limited with 47K miles has an interesting shudder.
It happened 3 times; the first 2 were right after oil change, one in 2010, one 2011. I did the oil change myself every 5K miles, Mobile 1 5W30, K&N filter. When I started it up, it shuddered badly, the whole body was shaking. I turned it off, and started it back up again, the shudder was gone.
The 3rd occurrence was yesterday evening when I left work for home. It started fine, but when I put it into Reverse, it shuddered; I put it in Neutral, the shudder was not as intensive, but still there. I put it back in Park and turned it off. When I started it back up again, as expected, the shudder was gone. The PT then took me home on a smooth ride as if nothing happened.
Does anybody here have similar experiences?
Old 18 Dec 2012, 04:46 pm
Default Re: random shudder
haven't had any similar instances. have you done the key dance to see if any codes were stored?
2016 Kia Soul Plus Black
Old 18 Dec 2012, 05:32 pm
edb edb is offline
It says "done".
Other than the 3 separate cases, the PT is running well. I am not sure if I should be concerned.
Old 18 Dec 2012, 06:10 pm
i'd be concerned. but then again, i'm pretty anal when it comes to my vehicles.
something has to be causing this.
Old 18 Dec 2012, 06:57 pm
Just guessing but sounds like an intermittent loss of voltage or fuel supply. You have a schreoder valve to test the fuel pressure, might want to test it and check all the cables on the battery fro any corrosion that might be built up.
Engine shudder with ac and heater rick2542 Tech & Performance Forum 2 29 May 2012 09:56 pm
shudder and sputter when in 4th gear pppt03turbo General Turbo Discussions 2 25 May 2012 08:35 pm
Cold start shudder ptguy69 Tech & Performance Forum 4 20 Jun 2011 11:14 pm
Light Shudder On Acceleration bob2006 Tech & Performance Forum 18 21 Dec 2010 03:30 pm
Shudder while accelerating from 20-30mph cnjvh General PT Cruiser Discussions 9 21 Dec 2010 01:46 pm
