Cooling Fan Relay
  • 1 Post By Ray_Dockrey
Old 18 Dec 2012, 10:27 pm
Default Cooling Fan Relay
Ok, well I took my car to the dealer and they said the fan was out so instead of paying the 650, we bought the fan and fixed it ourselves. Well now my check engine light is on and it says the high speed relay is out. So my question is where is it located at and is it easy or hard to change out. I drive a 2006 pt cruiser, 2.4, 4 cylinder. Any help would be appreciated. Thanks.
Old 18 Dec 2012, 11:18 pm
PTJunkie's Avatar
Default Re: Cooling Fan Relay
Maybe the fan was fine, and you just had a bad relay all-along.
...Oh,. and welcome to the forums.
William____
2004 Bright Silver PT Cruiser Turbo GT H.O
Old 19 Dec 2012, 08:32 am
Ray_Dockrey's Avatar
On the 06's and up when you replace the fan you replace the relays too. They are all part of the assembly. I would check the wiring going to the relays and make sure they are all tight and connected. The relays are on the shroud on the left (looking at the car) about a third of the way down. You can't miss them.
If they are tight then you might have gotten a fan unit with a bad relay.
Busted_PT likes this.
Cooling fan relay ? facts Tech & Performance Forum 11 22 Aug 2013 10:58 pm
Installed and new cooling fan and cooling temp sensor & still the fan doesn't kick in rdvarona Southeast PT Forum 18 31 May 2013 09:14 pm
Radiator/cooling fan relay part number for PT 06? TwoCats Tech & Performance Forum 23 24 Jan 2012 10:35 am
Hid kit relay beakerss Exterior Accessories Forum 6 03 Oct 2011 09:50 pm
A/c relay bigdee Tech & Performance Forum 0 22 Aug 2011 10:05 am
