Non Turbo to Turbo
Old 18 Dec 2012, 11:50 pm
Default Non Turbo to Turbo
Hi all, I have a chance to get a OEM Grille set that is black with the chrome inserts, only problem is that it is for a Turbo setup.
I see that the lower grille is a loose piece as opposed to the molded in type on my Non turbo.
My question is, is there any way to adapt the turbo lower grille to my lower valance, by trimming the old non grille and adding the turbo.
I do automotive prototype for a living, so doing rework to automotive stuff is not out of reach of my knowledge, so in other words "I ain't afraid of cuttin on my PT" so long as it halfway feasible. Thanks
A still runnin' 01 Limited,,all with a little prayer, and a lotta elbow grease
Red tint tails, chrome trimmed grille, custom towel rack buttonless flamed shifter, auto dimming rear view, Homelink remote transmitter, driver seat drawer, MOPAR sub, lowered 1" rear, MOPAR/Borla dual tipped exhaust, chrome trimmed GT gauge/airbag surround, front 35% tint, and the ever so important Fuzzy Dice
Old 19 Dec 2012, 03:18 am
Default Re: Non Turbo to Turbo
Seeing as I have a GT, I don't see why you couldn't. I've never had a look at the standard 2.4 engine bay and setup underneath, but I assume it's almost the same minus the turbo, intercooler and a slightly different airbox. And I'm sure you intake manifold is made of different material. It is a PT after all. So you do want the turbo? Or do you just want the grille? I'm sure you already know this since you prototype cars for a living, but it isn't cheap man. Depending on the power you want to put out, you may need a new transmission so it will hold. Not to mention the cost of the lower grille, turbo kit, exhaust to go with the turbo kit, intercooler, and intake to fit the turbo kit. You also may need new injectors depending on your year. I know 05 GT's and up had the big injectors for upgrades, but I'm not sure about a standard 2.4L. I'd just ask a mechanic at your local Chrysler if it can be done. If anybody knows it's Chrysler. Look for details on the car and it should clear things up. Hope I helped in some way. It's a good question though man.
Old 19 Dec 2012, 04:09 am
needmoretoys's Avatar
My lower grille is molded too. Mine is an 03 Dreamcruiser same as a GT turbo. Maybe the 01 is different. Turbo(gt) didn't come out till 03. I'm not sure what that grille is for(year and model).
Lenny
FEBRUARY CRUISER OF THE MONTH
Old 19 Dec 2012, 06:45 am
I had a billet grille on my '02 PT (non-turbo) and moved it to my '05 turbo.
I kept reading that the lower grille on the turbo is bigger, but it cannot be by very much, because I think the lower piece fits fine.
I attached it using black zip ties on the vertical black bars on the billet grille to the slats on the stock grille - my stock lower grille is fixed, so the Billet one sits on top of it.
Old 19 Dec 2012, 08:39 am
I have seen that grill on both. If you have access to the bumper that it came off of you could trace the opening.
Old 19 Dec 2012, 10:52 am
Default Re: Non Turbo to Turbo GRILL
The thread topic title is absence accurate titling?
It is just a suggestion but you might ask Carey aka CREWZIN to add the word "GRILL" to your thread topic. Anyone looking to up grade from a NONE Turbo PT to a Turbo engine application using the search feature is going to get this thread about grills? The title is a bit deceiving without the suggested word?
I am sure that the hit count will raise if left as it is?
60
Old 19 Dec 2012, 10:58 pm
Default Re: Non Turbo to Turbo-Grille
Sorry about the title being a bit misleading, I wound up writing it about midnight waiting for my dog to finish his business outside, and get to bed.
Anyway, thanks for all of your replies, and yes it is just for the grille, although I would LOVE to abscond a turbo setup for my ride
The grille is off of a 03 GT according to the ad.
I still am getting mixed ideas on what will work. Did the 03's have a separate lower grille? or was it just the Turbos that year having that feature.
I would like to be able to graft the lower grille offered in the ad, as long as I do not have to destroy my valance too bad, to do so.
Originally I was going to buy the chrome aftermarket overlay (the type ROCKETMAN has on his PT) and put the blackout kit on the vertical supports on the grille itself, but when I went to look it up, this OEM version appeared.
I just want to make sure it is worth my while, or just go back to my original plan. Thanks again.
Old 20 Dec 2012, 09:07 am
It requires you to cut out the lower grill. These bumpers are shown used on eBay sometimes. This not a GT thing some turbos had them some n/a had this.
Driving impressions: 05 Turbo-Lite and 06 Turbo High Output trooplewis General Turbo Discussions 31 25 Oct 2012 04:21 pm
Coolant Overflow Tank Turbo/Non-Turbo? DriftWoody General Turbo Discussions 5 06 Aug 2012 10:43 am
Turbo stuffs Manifold srt4 stage 3 SMT6 Turbo t3t4 50 trims and more bobgt Classifieds: For Sale/Trade 1 10 May 2010 02:29 pm
Colima Pro Street Shadow Turbo VS PT Cruiser Turbo skylight PT Cruiser Videos 5 31 Dec 2008 03:21 pm
180HP turbo lite and 215HP turbo difference. alceryes General Turbo Discussions 27 29 Dec 2003 01:57 am
