'06 Front window switch light??
Old 18 Dec 2012, 11:59 pm
Wink '06 Front window switch light??
The tiny light in the lever itself is out on my drivers side front window switch, any idea how to fix it?
Old 19 Dec 2012, 03:56 am
Default Re: '06 Front window switch light??
I don't have an 06 so I wouldn't know if this is exactly correct but I'm going to assume that it is a L.E.D light that went out.
You should remove the switch and see if there is a small removable bulb that you can just replace (not likely from my experience with other vehicle light switches). If you are good with soldering, you might be able to remove the old bulb and replace with another l.e.d. bulb. If not you might just have to replace the switch.
Personally, if it came down to either soldering or replacing the switch....I would just leave it alone. It is a small light that doesn't really have too much importance.
Old 19 Dec 2012, 04:12 am
needmoretoys's Avatar
See if this helps.
Power window switch disassembly Part 1
Lenny
FEBRUARY CRUISER OF THE MONTH
Old 19 Dec 2012, 05:40 am
Wink Re: '06 Front window switch light??
Thanks guys so far! My Wife says leave it alone...its her vehicle (GT with Turbo, no less-lol) but I hate bulbs (or leds) being out.
Old 19 Dec 2012, 05:11 pm
I'm the same way. My wife scolded me once for taking apart the entire center console of one of my previous cars to replace the rear ash tray light. I don't smoke, and I never sit in the back, but I had to replace it because it was burned out!
-Chris
Old 19 Dec 2012, 08:48 pm
My OCD will not allow the statement above to enter my brain and stay there!
window switch wcerqua Tech & Performance Forum 2 01 Dec 2012 04:23 pm
2001 window switch ptcruzer4 Tech & Performance Forum 1 22 Sep 2011 08:36 pm
Window switch help? Ronkelley General PT Cruiser Discussions 3 11 Apr 2011 07:04 pm
Window switch lights thender General PT Cruiser Discussions 9 24 Nov 2009 09:21 am
Front door Interior light switch namvetmike General PT Cruiser Discussions 2 29 Jul 2003 05:10 pm
