Leaking fog lights, can they be resealed?
Old 31 Dec 2012, 01:10 am
Default Leaking fog lights, can they be resealed?
I have been doing a bunch of body work on my wife's 2001 PT. In between coats of paint I have been polishing the headlights and fog lights. The headlights came out great but the fog lights look like they are leaking and water is getting inside. Once I polished the out side of the fog lights I can see moisture on the inside. It looks like you maybe able to separate the lens from the body and reseal them, but I wanted to see if anyone has attempted this before I tear my lights apart. Thanks.
Old 31 Dec 2012, 07:53 am
Default Re: Leaking fog lights, can they be resealed?
They should have come from the factory pretty well sealed. Anything should be able to come apart. We've had people take apart the headlights and tail lights so I'd imagine the fogs also could be taken apart. Look at the back end where the bulb goes into the light. Should be pretty well sealed and that may be where the moisture is coming from.
Old 31 Dec 2012, 10:24 am
rcktpwrd's Avatar
You can get new TYC brand fogs from Rockauto for about $20 each. I installed them on mine a year or so ago and they still look new. My original ones were very pitted and the chrome was mostly gone. They are easy to replace too...
Joel
www.rcktpwrd.com
Old 31 Dec 2012, 01:11 pm
If you can find the leak, a $3 tube of 3M bathroom caulk in black or clear *your choice :-D* will plug it up pretty dang well too :-D
Leaking red oil jsparr Tech & Performance Forum 8 04 May 2011 09:55 pm
Thansmission Leaking !!! Help..... RedPT07 Tech & Performance Forum 3 22 Dec 2010 10:14 pm
Leaking oil cap? CreepyPT Tech & Performance Forum 3 29 Oct 2009 12:16 am
Oil Leaking kairobsor Tech & Performance Forum 4 30 Aug 2009 01:10 am
oil leaking ptma767 General PT Cruiser Discussions 11 20 Feb 2008 07:42 pm
