Cruiser revs up then stalls
Old 31 Dec 2012, 12:15 pm
Post Cruiser revs up then stalls
Hi, i have a 2002 2.0 UK PT Cruiser Touring.
I have had a problem in getting it started over the last few weeks. It turns over starts and revs us then when the revs drop it stalls. The only way i can keep it going is to rev it up a few times till it warms up a bit then it runs fine. Anyone have any idea/experience on how to fix the problem?
I have put on new spark plugs and new ignition leads and changes the oil and filters. it also doesnt register any codes.
Also it stalls when the revs drop when i have it in full lock. Is this a common problem and are there any solutions to the problem?
Many thanks
Old 31 Dec 2012, 01:01 pm
Default Re: Cruiser revs up then stalls
Many thanks
Things to check.
Fuel pressure.
Camshaft sensor
Idle Air Control Valve
Catalytic converter
Throttle Position sensor
Anyone one of these could cause the vehicle to stall when the revs drop.
Mine ran like junk with low revs , turned out my IAC was gunked up.
Hope this helps
Old 31 Dec 2012, 02:32 pm
IAC is the first suspect as is the idle position. The first can be cleaned.
Old 08 Jan 2013, 03:43 pm
Thanks for your help. After cleaning out the IAC it now runs like a dream.
Cheers.
Old 09 Jan 2013, 09:47 am
Cheers.
You might try some Lucas Fuel system cleaner periodically to keep things happy....
Tags
cruiser, fulllock, revs, stall, start
2001 PT Cruiser stalls Roderstyrd General PT Cruiser Discussions 8 10 May 2012 01:37 am
'03 Cruiser Stalls, Won't Start bjagd02 General PT Cruiser Discussions 5 22 Feb 2011 06:33 pm
Engine Revs in Pulses with Full Acceleration - PT Cruiser ralpharino567 Tech & Performance Forum 5 23 Sep 2009 08:05 pm
Cruiser 'stalls' when going thru 2500 rpm jas0xgy Tech & Performance Forum 16 19 Aug 2009 03:00 pm
04 pt cruiser stalls when put into drive CCRMARATTA Tech & Performance Forum 7 27 Dec 2007 09:54 am
