No ignition, please help!
Old 02 Jan 2013, 02:20 pm
Default No ignition, please help!
Hi,
I have a 2004 Cruiser 2.2L and for some reason I have absolutely no ignition.
I can get the miles etc... on the dashboard. Lights work fine except when switched on the miles on the dashboard go extremely dim.
The interior lights work, electric doors and windows are fine.
However, the radio does not work either.
If I turn the key to try and turn the ignition, absolutely nothing happens.
I have checked all the fuses in the main fusebox under the hood. Checked the most obvious fuses inside the car.
Does anyone know what could cause this? What would the next place to check be? It seems very odd!
Thanks!
Old 02 Jan 2013, 03:43 pm
Default Re: No ignition, please help!
does the ignition feel funny when you turn the key? like, easier to turn than normal?
Old 02 Jan 2013, 03:58 pm
Hi rob342,
hmm, It seems to feel normal, I've not noticed anything different.
Is it possible it could be the ignition switch causing this?
Thanks,
Nick
Old 02 Jan 2013, 04:04 pm
Any unusual lights on in the dash? Blinking red light or anything. Do the head lights dim when you turn to start?
Old 02 Jan 2013, 04:19 pm
Hi,
Nope there are no unusual lights on at all. The headlights don't din when you try to start either.
I'm really not sure what it could be. It seems very odd!
Any other ideas would be welcome too!
Thanks!
Old 02 Jan 2013, 04:36 pm
sanatanadharma's Avatar
I assume that you have an "export" as known on this side of the sea.
Fuse #1 (30 amp) in the PDC is the most likely problem. The ignition switch is the next target.
If its diesel, I get to start over.
Originally Posted by nickcruiser View Post
Hi,
I have a 2004 Cruiser 2.2L ...I can get the miles etc... on the dashboard. Lights work ...The interior lights work, electric doors and windows are fine.
... radio does not work either.
If I turn the key to try and turn the ignition, absolutely nothing happens....Thanks!
Posting in stealth will not be permitted in most threads please read the forum guidelines.
Old 02 Jan 2013, 04:38 pm
Hi rob342,
Thanks,
Nick
not the ignition switch itself, it's the skinny little rod running from the lock cylinder to the switch. they break from time to time.
this isn't the problem. if it was it would not feel like it was springing back when you tried to start it. i just brought it up because it's happened to me.
hope you get it figured out
Old 07 Dec 2015, 06:34 am
Just noticed this post and is exactly the same as the problems i am having!
Does any1 know a solution?
Thanks
Old 07 Dec 2015, 09:01 am
What year is your PT Cruiser?
Does your PT Cruiser crank over? If not check the 12 volt line coming from the ignition switch to the starter.
Old 07 Dec 2015, 04:49 pm
Have you guys tried cleaning the battery posts and cables? You might just have a crappy connection somewhere.
%#^&&* ignition key!! wompus General PT Cruiser Discussions 19 02 Aug 2013 04:57 pm
Ignition Stuff PTCruisn81 Tech & Performance Forum 2 27 Aug 2012 09:44 pm
Ignition key sticking nfsdude007 General PT Cruiser Discussions 3 11 Jul 2011 07:42 pm
msd ignition oeldisplay Tech & Performance Forum 4 19 Jan 2009 05:32 pm
Ignition Key uskeith Tech & Performance Forum 7 17 May 2008 05:45 am
