Does the battery need a cover?
Old 04 Jan 2013, 01:26 am
Gru's Avatar
Gru Gru is offline
Default Does the battery need a cover?
I was cleaning the air filter for the first time tonight and realized that the previous owner had attached a battery cover to the Airaid air box. Other than a sense of asthetics, is there any reason for this? Is there any form of competition, autocross or something, that requires a modification like this?
Also, it seems like some tube that I thought was attached to the air box was just resting against it. At least I think it was, it doesn't seem to attach anywhere.
In case I don't see you...
Good afternoon, Good evening, and Good night.
Old 04 Jan 2013, 02:48 am
Default Re: Does the battery need a cover?
Got a picture?
Old 04 Jan 2013, 05:24 am
Battery covers are usually used when the battery tie downs are not tied down, if the battery were to lets say "jump" and the posts were to touch the hood, it would short the circuit, shut down the car, and possibly implode said battery.
Now with the PT having the battery hidden UNDER the air cleaner box, i dont see how this could be possible, My Opinion is the previous owner put it there for aesthetics, autocross in a PT is most likely NOT a reality , subaru yes, PT no lol
If ya dont like it, get rid of it, if you like it, keep it :-) but generally its useless unless you have some type of engine bay modification that would cause metal to ground out your battery?
Old 04 Jan 2013, 08:20 am
crewzin mentioned there is a factory heat shield around the stock battery. mine is missing and my battery failed when it was 100* every day this summer. heat kills batteries. maybe it has to do with that.
or another guess
i needed a NHRA approved box when i put mine in the trunk of my beater. no reason to do it under the hood. maybe it was leftover from a more serious project an he thought it look nice.
To the Rear
The NHRA requires that all vehicles competing in any sanctioned race must have the vehicle's battery box placed in the rear of the vehicle. The rear of the vehicle is anywhere behind the driver's seat or compartment. A popular place for vehicle owner's to place the battery box is in the vehicle's trunk.
Aluminum and Steel
The NHRA requires that a metal casing shield the driver's compartment from the battery. As of February 2011, the NHRA accepts both aluminum and steel battery boxes. Aluminum boxes must measure at least .032 inch thick and steel boxes must measure at least .024 inch thick.
Plastic Boxes
The NHRA requires that the battery be completely sealed off from the driver's compartment. Currently, the NHRA accepts only one brand of plastic battery boxes, which are sealed and held in place by 3/8-inch steel rods.
Old 04 Jan 2013, 09:27 am
No battery cover needed - on most cars you can easily spot the battery.
Hose to airbox is crankcase vent - probably a bit of oil diripping out the end... - no harm except it'll drip oil and make a mess.
Old 04 Jan 2013, 09:42 am
or another guess
To the Rear
Aluminum and Steel
Plastic Boxes
That's so in Drag Racing if you stop using the method or rolling over on your top the battery would not come flying forward and hit you in the head!
Old 04 Jan 2013, 12:49 pm
Gru's Avatar
Gru Gru is offline
Thank you. That's what I was thinking but I wanted to be sure.
As far as autocrossing being laughable in a PT, I would have agreed until I drove this one. At the very least, the previous owner has lowered it, put 17" rims on and a glasspack exhaust (along with the high flow filter, of course). There might be other modifictions but I haven't really spent any time down under.
Whatever has been done, the result is a very flickable vehicle. I am absolutely shocked. Its actually very easy to make this thing oversteer. It might even be a more usable oversteer since you don't need to be on the gas to make it happen. I can come into a turn hot, let off the gas, have the back end start to slide out, so I can get back on the gas sooner and keep it on through the end of the turn.
I know, head-to-head it probably wouldn't beat a Miata or something with more horsepower, but it would be fun to try. Anyway, if there is a class race where like vehicles go against each other, I feel confident that I would be competitive.
Old 04 Jan 2013, 12:53 pm
If the cover is what I'm thinking it is, it's just an insulation. A lot of the heavy duty Ram trucks have inslation around the batteries to protect them from the cold, so they'll start in the winter.
-Chris
battery cover demon666 Tech & Performance Forum 7 16 Aug 2009 09:40 pm
Battery cover turbomangt General PT Cruiser Discussions 7 05 Mar 2004 09:09 am
GT Battery Cover ModernRT General Turbo Discussions 13 16 Oct 2003 05:03 pm
Battery Cover for Sale CREWZIN Classifieds: For Sale/Trade 2 27 Jul 2003 04:30 pm
Battery Cover Jerry General PT Cruiser Discussions 1 03 Oct 2002 10:19 pm
