2.2 CRD 2006 not charging?
Old 05 Jan 2013, 09:39 am
Default 2.2 CRD 2006 not charging?
Hello guys.
Got myself a PT Cruiser 2.2 CRD 2006 which stopped charging some day i drove it, and the batt. light came on. Just changed the alternator and the car is still not charging.
No output on the Alt what so ever. Really cant figure out the problem.
No P-Codes in the display, it only says "D0ne".
Hope you guys will help.
Morten
Old 05 Jan 2013, 09:47 am
Default Re: 2.2 CRD 2006 not charging?
double check the connectors, make sure they are seated properly.
assuming you have both connectors reattached to the alternator and the belt on, i would guess they gave you a bad alternator. i have gotten a dead one before. usually swapping it again is the easiest thing to try before you try to track down a wiring or ECU issue. now i have them tested before i leave the store
Old 05 Jan 2013, 09:56 am
Hi Rob
Already tried 2 alternators, both checked.
You know how many volt that should be coming out of the blue signal wire, that you connect to the alternator?
Old 05 Jan 2013, 10:43 am
Originally Posted by MortenC View Post
Hi Rob
i have nooooo clue. over here the alternator is connected different colored wires. i have no info available about the CRD models. from reading the stuff i copied and pasted below, it would appear that if you disconnected one of these wires(don't know which) it would go into safe mode and supply a 25% charge that you could measure. if you can get it to do that, it may help you isolate your problem.
hopefully someone more qualified in this can assist you. i'm not a certified technician by any means.
The Electronic Voltage Regulator (EVR) is not a separate component. It is actually a voltage regulating circuit located within the Powertrain Control Module (PCM) . The EVR is not serviced separately. If replacement is necessary, the PCM must be replaced.
The amount of DC current produced by the generator is controlled by EVR circuitry contained within the PCM. This circuitry is connected in series with the generators second rotor field terminal and its ground.
Voltage is regulated by cycling the ground path to control the strength of the rotor magnetic field. The EVR circuitry monitors system line voltage (B+) and calculated battery temperature or inlet air temperature sensor (refer to Inlet Air Temperature Sensor, if equipped, for more information ). It then determines a target charging voltage. If sensed battery voltage is lower than the target voltage, the PCM grounds the field winding until sensed battery voltage is at the target voltage. A circuit in the PCM cycles the ground side of the generator field at 250 times per second (250Hz) , but has the capability to ground the field control wire 100% of the time (full field) to achieve the target voltage. If the charging rate cannot be monitored (limp-in), a duty cycle of 25% is used by the PCM in order to have some generator output.
Old 05 Jan 2013, 11:22 am
Hmm okay.
You know if i need to reset the fault codes, before it will start charging again then? To get it out of the safe mode
Charging System Help RMoore Tech & Performance Forum 21 27 Aug 2012 09:28 pm
pt not charging. eli Tech & Performance Forum 1 30 Jul 2011 02:03 pm
Charging problem lowridr General PT Cruiser Discussions 4 03 Nov 2010 09:18 am
UK crd charging question spiceweasel Tech & Performance Forum 6 15 Dec 2007 04:37 pm
Super charging Mr.Blonde Turbo Performance 7 29 Apr 2003 10:31 am
