Abs and trac lights on
Like Tree9Likes
Old 07 Jan 2013, 03:52 pm
Angry Abs and trac lights on
I know a lot of people have had this problem and I can't find a direct answer to what's wrong. My abs and trac control lights are on in my 2001 pt cruiser. I've had it tested and it says hydrolic pump circuit malfunction. Please help and let me know what's happening. Car has 168k and still runs strong.
Old 07 Jan 2013, 03:56 pm
mnahmnah's Avatar
Default Re: Abs and trac lights on
I have a 2001 also.. I bought it used with those same lights on. Asked the service dept. where I bought it to check it out, and they couldn't determine why. I've driven it with them on for 50,000 more miles with no trouble. If I find out anything I'll let you know, but it seems like a mystery
Busted_PT left this on my thread:
Also abs and trac use the same sensors so check the plug connectors and wiring first.
So there's something to consider.
2001 LE, 168,000 miles.
One of the split seats went into a dumpster in Tulsa. The arm rest unscrewed and fell off. It's on its 2nd timing belt. Surviving the Upper Peninsula winters.
Old 08 Jan 2013, 06:26 am
Usually, it's a bad ABS sensor at a wheel. I don't know how he did it, but my mechanic found ou which one was bad and replaced it & taht was that.
I have also read that there is a toothed disk at each wheel that the sensor "looks" at, and sometines that toothed disk gets damaged.
What means of testing was used to determine "hydraulic pump circuit malfunction" - and why didn't whoever tested it tell you what's wrong and fix it?
By the way, that was the only problem I've had with my PT, and the other day it passed 111,111 miles....
Yes, I replaced plugs and wires and timing belt/water pump/other belts.
Old 08 Jan 2013, 09:28 am
It was tested through the abs system itself not the cheap test at the stores, it's been doing this for a year on and off when it was raining or snowing but now it's stuck on and trying to stop in snow is like driving a 70's camero. So I have to get it fixed. Seems like one problem after another. Owned 4 yrs was a show car when purchased with 40k but I do drive this thing long and hard still love it after all other problems I've had . Checked all fuses and wiring yesterday with nothing out of norm and reset battery and the mechanic tried resetting abs with code not resetting with tester either
Old 08 Jan 2013, 10:02 am
I do all the work myself on pt. unless I can't and the test was done by a buddy that work at Midas. He is not sure on code either because if hydraulic pump was bad it tell in my breaking of the car. But that's the code
Old 08 Jan 2013, 10:17 am
That is totally incorrect. The pump you're referring to is not your master cylinder its the abs pump. The big box that all the lines run into for the abs. also you are feeling it in your braking. You said you are having wheel lock under braking on snow.
Old 08 Jan 2013, 11:14 am
Yes the box under the master is what I'm talking about. With the lights on the system is shut down. It only locked up in snow once and the light just turned on and car went straight. Light shut off and car stopped sliding and turned. I have tried to lock up breaks on gravel and seems like it kicks in fine very little lockup, just like it should and that is with lights on. Your right about I would be feeling it in brakes when car locked up but I should feel it when I jam on brakes at 50 trying to lock them up too. Right?
Old 08 Jan 2013, 12:05 pm
If the wheel sensors are all ok then you may have a problem with the ABC controller. Not sure why the mechanic at Midas did not find this out? Although it is usually certified Brake Technicians that operate the diagnostic equipment there?
If the light is on you need to simply remember what it was like to drive a pre 80s" vehicle. Brake sooner then usually and try not to panic stop because you will lock up all the wheels.
In some states you can not re register your vehicle with a ABS light on.
I might add that in the case of anything brake related concerning cautionary light(s) or any abnormal operating condition coming to a forum for help is ill-advised. This is for the safety of not only yourself but everyone that shares the road with you.
Get someone in the Automotive Brake Certified Service to properly look over your brake system and diagnosis the problem.
dougs likes this.
Old 08 Jan 2013, 12:22 pm
All he did was check codes. Had 3 of 4 wheel sensors, hydro pump circuit, and 2 other things. All was due to brakes locking up. After reset just the pump circuit malfunction showed. All the wheel sensors were fine after we drove. He said hydro pump was out unfortunately this is a pt cruiser and nothing is what it seems on them. Or at least mine and something about the way it started I can't see a pump not working from getting wet.
And I understand not trusting a form, safety first but when everyone has the same problem someone has to have a solution.
Busted_PT likes this.
Old 08 Jan 2013, 06:24 pm
Having a certification doesn't mean he can do squat. It means he passed the tests. There is a difference mechanical ability and book smart. And it can't be thought. It has to be enhanced.
mnahmnah and spiral like this.
Tags
abs, trac off
Engine, ABS and Trac Lights on - Garage reorted no error codes AndyJay Tech & Performance Forum 15 03 Apr 2014 12:43 pm
Trac control or ABS? sptanz General PT Cruiser Discussions 10 30 Apr 2012 11:07 am
Swapped my PT, but have a new problem... ABS & TRAC OFF Lights on.... stek2008 General PT Cruiser Discussions 7 16 Dec 2010 08:27 am
abs trac light donny General PT Cruiser Discussions 1 01 Jun 2010 08:33 am
Trac Off HLeyes Interior Accessories Forum 3 15 Sep 2008 05:52 pm
