Engine died while driving, now won't turn over. Need help finding problem
Old 10 Jan 2013, 08:39 pm
Default Engine died while driving, now won't turn over. Need help finding problem
I was driving on the highway (70 mph) and the engine suddenly shut off. It felt like it went into first gear at the same time, the engine revved up really high and I then put it in neutral. I coasted to the side of the road and now it won't do anything when I turn the key. No noise or clicking of any kind. It has 110,000 miles on it and I've had it since 100,000 miles were on it.
I'm afraid the engine is seized up or something like that, but I'd like some help finding the most likely problem (engine seized, transmission bad, timing belt, starter...). I don't think it's the starter because that wouldn't cause it to suddenly shut off while driving. I'm not sure about the timing belt, but I tried to pull back the cover enough to see it. It looks like it's still intact and when I press on it, it feels like the belt is still tight. But I don't have enough clearance from pulling back the cover to see it in entirety.
I removed the valve cover and took some pictures, here is an album of them: 2005 PT Cruiser Convertible 2.4L Turbo Engine - Imgur
Does anybody have a good guess at the problem? I can post more pictures or answer anything else about the car. Thanks
Old 10 Jan 2013, 09:03 pm
Default Re: Engine died while driving, now won't turn over. Need help finding problem
I believe you through rod. I only say this because of the the rev thing. Had similar thing happen once. I would see if you can turn the crank buy the bolt. Pull the plug it will make it easier.
Old 10 Jan 2013, 09:08 pm
jrbsr05pt's Avatar
You can check the timing belt by removing the cam shaft sensor and have someone try to start it. If it doesn't turn the it could be your timing belt. But then again you said its not turning over at all. So that probably won't help. Just figured I'd throw that out there just in case
2005 n/a 5 speed. 177365 miles. spectre cold air intake, white and pink leds under dash and back seats, purple leds in vents, wall with 1 18" subwoofer built behind back seat(soon to be either 16 American bass vfl8's or 4 18's with the wall rebuilt all the way to behind the front seats,cant wait!!!), blue dash lights, pink turn signal indicators. 3D tails and tinted backup lights. Power antenna (that no longer has power ha!) another one gone but wont be forgotten
2003 gt turbo. 130245 miles. autostick, mopar riceplate, 3" o2 housing and downpipe. custom diablo tune (totaled, gone but not forgotten)
2003 dream cruiser. autostick, mopar body kit, mopar bov, cai. s1 injectors. mopar s1 pcm. 3" 02 housing and downpipe installed from last turbo, upper IC hardpipe more on its way soon.......... diablo tuner in the near future.
Old 10 Jan 2013, 09:14 pm
Based on your description - sounds like tranny went - disconnected engine from tranny - you say it felt like a downshift and engine revved high. (except you say engine died, so how could engine rev high??)
Maybe now it doesn't see that tranny is in Park, which would keep it from turning starter.
If it was timing belt, starter would still turn.
Any engine codes?
Old 10 Jan 2013, 09:19 pm
jrbsr05pt's Avatar
I know. That's why I said what I said wouldn't help but figured I'd go ahead and post it anyways because the fellar said he tried pulling back the cover and wanted to let him and whoever else that may read this, that there is an easier way.
Old 10 Jan 2013, 09:32 pm
I will try this, I'll have to figure out how to do this first
Old 10 Jan 2013, 09:35 pm
Any engine codes?
Yes, the engine shut off and it immediately felt like it went in 1st gear. The engine shut off, but since it was in a low gear and I was on the highway, it made that high rev noise
Old 10 Jan 2013, 09:49 pm
That sounds different. If engine seized, I would think starter would click and try to turn...
Have you tried for codes??
How to retrieve fault codes.
Old 10 Jan 2013, 09:59 pm
The check engine light is not on, and when i check for codes, there aren't any returned.
Old 10 Jan 2013, 10:08 pm
I bet you its a fuse. Sounds stupid I know but the same thing happen to me. I believe its fuse #15.
Weird rumbling noise in dashboard when I turn over the engine/ turn off the engine... thinkinboutit Tech & Performance Forum 5 22 Jan 2014 08:23 pm
2001 Died while driving compguy Tech & Performance Forum 3 07 Aug 2013 11:43 am
2003 PT Cruiser died while driving tlm Tech & Performance Forum 6 24 Sep 2011 01:47 pm
Engine died while driving, Blown ASD fuse & VERY Hot MyCruiserHatesMe Tech & Performance Forum 11 10 Aug 2011 08:50 am
02 PT died won't turn over mschneider Tech & Performance Forum 3 20 Apr 2011 01:32 pm
