Engine vibration on stop
Old 13 Jan 2013, 11:10 am
Default Engine vibration on stop
I have a 2007 touring pt cruiser 2.4 engine. The engine have a strange vibration on stop with Drive or Neutral speed selected, when the engine speed is about 650-700 rpm. When I acelerate a little bit, the vibration dissapears. I note that the vibration is harder when the outside temperature is hotter. I already changed the spark plugs, cleaned the injectors and the acceleration body, the wires are alright, the motor mounts are new. The vibration is hard enough to make all the car body shake. Thank you in advance for your responses!!
Old 13 Jan 2013, 02:50 pm
Default Re: Engine vibration on stop
Check that your engine fan works. Open hood, start engine, turn on A/C, and go look.
engine vibration dewey68 Tech & Performance Forum 8 26 Apr 2012 05:02 pm
engine vibration bjm1088 Tech & Performance Forum 20 21 Apr 2011 01:18 pm
Went to stop and engine raced.. hawky Tech & Performance Forum 4 04 Jul 2010 08:27 am
Y engine turns off when i stop BSTING General Turbo Discussions 2 09 Jun 2010 08:38 am
vibration in drive at stop manzanman Tech & Performance Forum 2 06 Apr 2010 05:33 am
