Winding noise! Please help!
Old 14 Jan 2013, 01:39 pm
Default Winding noise! Please help!
I noticed a annoying winding noise when I turn the wheel! So you think the pump is completely bad? Thanks in advance guys!
03 Pt 5spd and lovin it!
Old 14 Jan 2013, 02:00 pm
cruserdad1976's Avatar
Default Re: Winding noise! Please help!
did you check the fluid????
Old 14 Jan 2013, 02:38 pm
mnahmnah's Avatar
Is this something like a barely audible squeak at the steering wheel? Mine sounds like that for a long time, turning the wheel, but I thought it's just plastic rubbing. ?? I realize there should be no noise but there's a lot of noises all over my car,that's just one. Is that sound similar?
2001 LE, 168,000 miles.
One of the split seats went into a dumpster in Tulsa. The arm rest unscrewed and fell off. It's on its 2nd timing belt. Surviving the Upper Peninsula winters.
Old 14 Jan 2013, 02:46 pm
Deepstar's Avatar
I had winding noise on my 01 when I turn to the left. It started when we had flooding rain here. Two nights later my timing belt failed. In the shop now, will repost if they tell me power steering pump is bad also. Power steering fluid was still full though.
Old 14 Jan 2013, 05:25 pm
compdr59's Avatar
It's probably the wife!!
Does the sound disappear when you raise idle speed? Try flushing the fluid, it will only cost $6 in ATF +4. On my 2001, I had the pump replaced twice, once for the noise and one for a severe leak. There was a recall for relocating the PS lines that made an improvement. Not sure if it applies to your 03.
Original Owner 135k
Old 14 Jan 2013, 08:00 pm
Thanks guys. It ended up being a leak in one of the lines.
In between a whine & winding noise, almost a hot rod sound...running very rough desarae77 Tech & Performance Forum 1 27 Aug 2012 07:29 pm
My Car Makes Hissing noise when driving.. no noise from reverse or netural kasasoze Turbo Performance 3 04 Dec 2011 09:07 pm
Winding Freezinghot Tech & Performance Forum 6 05 Oct 2010 12:48 am
Winding down sounds Cliff5550 General PT Cruiser Discussions 11 11 Dec 2008 04:33 pm
