Power problem? Not sure!
Old 14 Jan 2013, 08:45 pm
Default Power problem? Not sure!
Hey guys. I recently noticed when I am driving at night with my headlights when I apply the breaks or use my turn signal it dims. Thanks for your help
03 Pt 5spd and lovin it!
Old 14 Jan 2013, 09:25 pm
Ray_Dockrey's Avatar
Default Re: Power problem? Not sure!
My 09 does the same thing. On mine it's the battery. I am replacing it tomorrow. I would check all your cables and make sure they are clean and connected well. I would also have the battery checked.
Old 14 Jan 2013, 10:01 pm
As Ray said. Make sure you check all the cable connections. Not just at the battery.
Old 14 Jan 2013, 10:57 pm
Well I am running a 1,000 watt amp with HID headlights and an aftermarket alarm and horn. Would adding a compositor for my amp help balance out the amount of energy I'm using?
Old 15 Jan 2013, 07:00 am
And I'll bet the lights don't dim when amp is off??
Not sure a CAPACITOR will do it - you might need a stronger battery and alternator.
Old 15 Jan 2013, 08:29 am
This would have been helpful info in your original post.
Old 16 Jan 2013, 01:59 am
I would do the big three if you haven't already and add a agm battery under your hood and one small one in the back next to your amp. And put a fuse between that rear batt and the amp. Anytime you run 1,000 watts or more it's time to start thinking about upgrading electrical and anytime you run more than 2,000 watts it's time to start thinking about upgrading your alt. Hope this helps some!
The LedGlow Cruiser]
[COLOR="Black"]-Soundstream vir 8300-NR touchsreen headunit
-6 skar vvx 12's (dual 4 ohm)
-12 cubic foot box tuned @ 32 hertz
-re audio mids and highs
-Dc audio 3.5k
-Mechman 240 amp alt
-Cadence 0 gauge all around
-Plasti dipped rims and bumpers
-"Blue" VVME HId low, 15k high beams.
-149 db @ 38 hertz (need to get re metered)
power outlet problem yteka99 Interior Accessories Forum 19 20 Aug 2011 03:41 pm
Power windows problem PJcruiser General Turbo Discussions 10 20 Feb 2011 04:41 am
Possible Power Steering Problem ptbeard Tech & Performance Forum 6 20 Nov 2010 09:06 pm
Power window problem droptopman Tech & Performance Forum 2 29 Mar 2010 07:32 pm
Yet another Power Steering problem fritz_t_coyote Tech & Performance Forum 3 23 Nov 2005 04:28 pm
