Sunroof repair
Old 16 Jan 2013, 08:36 pm
Deepstar's Avatar
Default Sunroof repair
I need to replace one of the brackets on my sunroof.I wanted to know if anyone know the correct procedure to remove the interior to get to the sunroof without tearing anything up.
Old 26 Aug 2013, 08:17 am
Default Re: Sunroof repair
Hello,
Did you find out anything? Mine is broken and I see eBay has a kit for $120.00. I am pretty mechanical, but any tricks or tips?
Old 26 Aug 2013, 08:32 am
Originally Posted by Howardh View Post
Hello,
You must remove the plastic pillar trim and shoulder belt mounts. Also remove all the peaces mounted through the headliner. The push through pegs in the rear are best removed by easing the head liner out from the rubber in the hatch area and with your hand flat push down at the peg location and they will pull right out. The wiring for the sunroof is mounted to the headliner. so unplug this. Also there is a plug on both front pillars the the wires run up the posts that need to be disconnected and popped lose from the pillar. Then you have 8 10mm headed bolts that hold the sunroof in place. Leave one in the middle of each side but lose. Then with seat up lower one side at a time and slide out the back.
sunroof silversurfer Exterior Accessories Forum 5 29 Dec 2011 12:54 am
sunroof help neon95 General PT Cruiser Discussions 2 19 Mar 2009 01:12 pm
Sunroof blondecowgirl Interior Accessories Forum 3 21 Jun 2007 02:14 pm
sunroof HELP!!!!!!!!!! Lana Interior Accessories Forum 4 25 Sep 2006 04:38 pm
Air Dam for Sunroof hugh_mack General PT Cruiser Discussions 1 22 Nov 2002 08:38 pm
