02 pt with p0340 code
Old 19 Jan 2013, 11:22 am
Default 02 pt with p0340 code
Wife was driving pt lastnight comming home and it stalled.. Wouldnt start back up.. I went today to get the car and had 2 codes one for oil presser sencor and p0340.. Its dead in the water any ideas?
Old 19 Jan 2013, 11:26 am
Default Re: 02 pt with p0340 code
It's either one of two things (maybe three). The timing belt has broke or you need to buy and install a new Camshaft sensor. Possibly, the Oil Pressure Sensor switch needs replacing also.
Do you have any technical experience meaning, do you do any of your own work? Second question, how many miles on your car?
Old 19 Jan 2013, 11:28 am
I can do some work my self miles is 70,000 I will replace the sensor tonight any way to find out how the timing belt maybe broke?
Old 19 Jan 2013, 11:33 am
At your miles, it's probably the Camshaft sensor and not the timing belt but a way to check it is to take the Camshaft sensor off, have someone try and start the car and see if the magnet (inside the hole where the sensor was) turns when you try and start the engine. if it doesn't turn, the belt is gone but you shouldn't have that problem at your mileage.
P.S. Spend a little more money and buy a MOPAR Camshaft sensor at the Chrysler dealer rather than a parts store. PT's have problems with aftermarket sensors. When/if the car starts, then see if the Oil Pressure sensor light is still on. Take off the battery cable when replacing the Camshaft sensor.
Old 19 Jan 2013, 11:50 am
OK when I get off Im going to test for the belt to be broken first where do I find the cam shaft sensor?
Old 19 Jan 2013, 11:56 am
It's the one marked CMP.
Old 19 Jan 2013, 11:58 am
If the belt is bad how hard is it to change...
Old 19 Jan 2013, 12:21 pm
If you have to ask, you'll need it done professionally. In a range of 1 star = easy and 5 star = hard. The PT cruiser timing belt = 5 1/2.
Old 19 Jan 2013, 12:27 pm
We have a how to section in the tech section. It's a lot of work and requires some tools. Many have done it. Take pics before taking things off helps in remembering where things go back. Some tools you can make up yourself and save big bucks.
Old 19 Jan 2013, 07:10 pm
Well guys I took off the camshaft sensor and had wife try and start...... nothing happened but a lil oil cam out does that mean timing belt?
Code P0340 flcruiser General PT Cruiser Discussions 1 24 Aug 2012 07:08 pm
P0340 code Travis2k7 Tech & Performance Forum 18 10 Jul 2012 09:40 pm
P0340 Code DragonBuddha06 Tech & Performance Forum 3 13 Sep 2011 09:06 pm
P0340 Code. BlackJack Tech & Performance Forum 10 01 Mar 2010 09:26 pm
Code p0340 tommyis3 General Turbo Discussions 3 16 May 2009 01:51 pm
