Driver side seatbelt stuck! Please help!
Like Tree4Likes
  • 1 Post By Carl48
  • 3 Post By Youngmaninanoldmanscar
Old 21 Jan 2013, 09:17 pm
Default Driver side seatbelt stuck! Please help!
So today I got on my car reached over to get my seatbelt on and I heard "click" and it wouldn't budge a bit! Sound like when the seatbelt locks when you pull it to fast! Anyone had this problem? Please help!
03 Pt 5spd and lovin it!
Old 22 Jan 2013, 06:40 am
Default Re: Driver side seatbelt stuck! Please help!
Any seatbelt problems I've ever had have been solved by pushing the belt all the way in (retracted) then pulling out slowly, making sure there isn't a twist in the belt.
Old 22 Jan 2013, 11:07 am
It's retracted all the way on already....
Old 22 Jan 2013, 12:12 pm
Be careful...that retractor may contain a pyrotechnic pre-tensioner.
Busted_PT likes this.
Old 22 Jan 2013, 12:33 pm
Is there an incline were you are parked. The pangolin may be stuck. Hey if that's not the right spelling it's the phones fault.
Old 22 Jan 2013, 12:34 pm
mnahmnah's Avatar
All i can think of is... make sure you didn't close some of the slack in the door. I've done slick moves like this before and blamed the car...
2001 LE, 168,000 miles.
One of the split seats went into a dumpster in Tulsa. The arm rest unscrewed and fell off. It's on its 2nd timing belt. Surviving the Upper Peninsula winters.
Old 22 Jan 2013, 10:03 pm
Took it all apart today! Long story short its fixed and I need a new plastic molding replaced....
Old 22 Jan 2013, 11:04 pm
Not tell'n what happens?
Old 22 Jan 2013, 11:39 pm
So the seatbelt is secured at the bottom with a torch screw that was already stripped! Then after I cut the plastic and got that off then you would never guess that there was another screw but I was able to get it out with channel locked then inside are some gears that were all jacked up and twisted so I took them apart and cleaned them and sprayed them with lube!
WTB: Driver Side Sunvisor 03TibbyGuy Classifieds: Want To Buy 4 18 Jan 2011 11:58 am
Driver side CV axel.... wheelgarage Tech & Performance Forum 1 17 Jan 2010 09:41 am
Driver Side Tail F/S... StoneWhitePT2 Classifieds: For Sale/Trade 0 26 Jun 2009 12:20 am
Stuck Drivers side seatbelt? CrnBrryCruiser Interior Accessories Forum 8 13 Nov 2008 11:29 am
Driver side too tall? Samurai Interior Accessories Forum 11 26 Aug 2007 08:23 pm
