No lights! Gremlins?
Old 23 Jan 2013, 09:31 pm
Default No lights! Gremlins?
'04 PT Touring, 130K miles. Left home after daylight, so didn't notice for a while that all my lights were out - headlights, fog lights, dash lights - when I got to work I pulled out the owners manual - 40A fuse #10 under the hood looked like the culprit (lights and door locks, also dead), so I swapped it with #9 (a spare). Turned on the light switch, still nothing. Door lock just clicked a relay. As it was about 7 degrees and windy, I stopped there!
Thought about calling somebody to look at it, but decided to take another look at lunch time. All fuses looked OK... then I noticed the lights were on, dim... Oh CRAP! Yeah, battery was almost dead... after a jump start I drove it for a few miles in lower gears to charge it back up. And of course the gremlins had hooked up whatever they had disconnected... all lights and door locks worked fine.
So... any ideas? What's between the battery connection and fuse #10 - is there a welded connection that could have popped? A wire connector? If it was at the fuse, I would had it at first try - I looked in the Haynes manual, but it's for the Euro version, different fuse box. I have the Chrysler diagnostic manuals, but doubt they'll be any help here!
Old 24 Jan 2013, 03:51 am
UptownSport's Avatar
Default Re: No lights! Gremlins?
Yes, when nothing's wrong it's hard to diagnose!!!
You did say battery was very low?
And was the original fuse actually bad?
Old 24 Jan 2013, 10:58 am
40A fuse was fine, battery was low because lights had come back on. I am thinking now there was a bad connection at the output terminal of the engine fuse box or input side of the inside fuse box - the one I DIDN'T look at... still, hard to imagine that kind of connection (8-10 gauge wire, BIG contact) going intermittent.
Old 24 Jan 2013, 11:09 am
Gremlins!? whatever you do......dont get your PT wet!. Seriously if its gremlins you will be sorry :-p
Check the fusable links :-D those tend to cause lots of lighting issues. Which is the best case scenario, when thinking about possible gremlins
Old 24 Jan 2013, 01:24 pm
It is sure tbavis. if you have chrysler diagnostic manual then it can give you help you
I'm back lol...well the gremlins are! DeviantPT General PT Cruiser Discussions 4 04 Apr 2012 05:31 pm
Electrical gremlins tservice General PT Cruiser Discussions 2 26 Feb 2012 09:42 am
pesky lil' gremlins mdskinner731 Tech & Performance Forum 7 22 Nov 2011 12:56 pm
Electrical Gremlins SantaGuy General PT Cruiser Discussions 10 24 Sep 2009 05:01 am
Gremlins? zzzhuh General PT Cruiser Discussions 1 02 Oct 2004 05:20 pm
