Front Bearing
Old 24 Jan 2013, 11:55 am
Default Front Bearing
I just took my 02 Pt in for a rotate and balance where I bought my tires(Tire Discounters). The mechanic said the left front press on wheel bearing has play, and I needed to have it replaced. Their quote was almost $300 dollars. Just curious if this sounds a little too much? I've replaced bearings on some of the older rear wheel drive cars, but never on a front wheel drive car. Is there much difference? Any positive opinions are appreciated. Thanks
Old 24 Jan 2013, 12:38 pm
Default Re: Front Bearing
You have to remove the brakes, rotter, caliper bracket. then the steering knuckle witch entails removing axle bolt. getting the ball joint and tie rod loose, and removing the two strut bolts. Then the bearing is pressed out then the new one pressed in.
Old 24 Jan 2013, 12:42 pm
Yeah, sounds like too much work for this "Shade~Tree~Mechanic" Thanks for the reply and info. Do you think 300 bucks is a little steep for this repair?
Old 24 Jan 2013, 01:05 pm
most of the time one goes bad, and then the other goes bad. it may be a good idea to see if you can get a deal getting both sides done at the same time, either at this shop, or elsewhere.
the other option to save money and make it less work to fix is taking the knuckle off yourself and having a shop press the bearing for a small fee
Old 24 Jan 2013, 01:14 pm
I'm not familiar with paying people to do stuff. Have to do myself.
It's not that hard if you have tools and know a trick or to to get the tie rod loose.
Old 26 Jan 2013, 06:45 pm
Matt42's Avatar
$300 is not out of line if they do the work well and use a decent brand of bearing, such as a Timken or NTN. Do not let them install a Chinese made bearing. I recently changed out both sides. Owning my own arbor press helped. I found that I could buy Timken bearings from Rock Auto for about $27 each. They were special order locally at $45. But locally for $27, all that were in stock was a house brand made-in-China bearing. Just be aware that the Timken box contained an NSK bearing, but that is an OK brand also.
1996 Dodge diesel 4X4, 2001 PT Cruiser Touring with rear disc brakes, [Now gone 2004 PT Cruiser Base 5 speed], 2007 Chrysler T&C Touring
Old 26 Jan 2013, 11:27 pm
not bad i paid $450 for one side :-p but then again i opted to change out the entire hub assembly and steering knuckle :-p which was $124 in parts alone
Old 27 Jan 2013, 09:07 am
I did mine using a harbor freight bearing tool. It depends how talented you are. The tool is 100 bucks, bearing is 45. Time is 2 hrs. I beat the hub out with a 1 1/4 socket. Carefully so as not to cut into the hub grind the inner race with a cutting wheel, split it and remove from the hub. Use the tool to remove the old bearing out of the knuckle. I had froze the new bearing for a couple days before, I then heated the knuckle in the gas grill to a couple hundred degrees. The cold bearing dropped right in. If you chill the hub it will also make it easier to pull into the bearing using the bearing tool. If I had 300 buck I would have paid to have it done!
Old 27 Jan 2013, 10:07 am
Matt42's Avatar
Oh, yeah! I replaced one of the hubs. I had cut into it a tiny bit with the dremel as I was getting ready to cut the bearing race off with a chisel. The cut was not very deep. But when I thought about all the forces acting on the hub, the less than $30 for the hub from Rock Auto was worth the peace of mind. You can be sure I did not make the same mistake on the other side.
I prefer to do my own work. That way, I know it is done right. While I had it all apart, I put on street and track brake rotors and pads. Those paid off the next month big time. An idiot kid on a bicycle darted into traffic. I literally stopped inches from him. With the old brakes, I would have hit him. Legally it would not have been my fault. But it would have been horrible.
How to tell which front wheel bearing is bad? sscanlan Tech & Performance Forum 21 13 Dec 2011 11:06 pm
Front Wheel Bearing?? mjb457 Tech & Performance Forum 3 12 Mar 2009 03:37 pm
How do you get the front bearing out of the HUB??? llcelebrity Tech & Performance Forum 5 10 Feb 2009 04:04 pm
Front Hub & Wheel bearing JoeHundredAire Wheels, Tires, Suspension 2 15 Jun 2008 11:25 am
front wheel bearing debspt Tech & Performance Forum 1 01 Oct 2006 11:42 am
