Which PCM to use?
  • 1 Post By Ray_Dockrey
Old 24 Jan 2013, 10:20 pm
Default Which PCM to use?
I am trying to install a 2004 PTGT 2.4 without the turbo and wondered which PCM I could use to make this work? I guess that the 2004-2007 PT 2.4 non-turbo PCM should to the trick. Could anyone either confirm or disprove my assumption? Thank you.
John
Old 25 Jan 2013, 08:56 am
Ray_Dockrey's Avatar
Default Re: Which PCM to use?
I don't think you can use the 06 and up. In 06 they went to the Canbus system and all the electrical changed. My guess would be that the wiring for the PCM would have changed also.
Busted_PT likes this.
Old 25 Jan 2013, 10:07 am
Not sure what year your car is. Just use all your electricals including your pcm. Also including your injectors. Only thing is the turbo engine is supposed to have less compression than a n/a. IDK.
