PT cruiser common problems?
Like Tree4Likes
Old 26 Jan 2013, 10:50 pm
Default PT cruiser common problems?
Hi there i just recently purchased a 05 pt touring addition for 800 bucks ( i know crazy good deal) put a new battery in a it runs like a champ. It was sitting for 6 months and its very cold where i live. i was wondering what i should look out for as common problems that i might be able to catch early. FYI it has a new water pump and timing belt. only noise that out of the ordinary is the best squick ?? maybe just because of the cold im not sure. Any and all information is appreciated thanks !!
Old 26 Jan 2013, 11:02 pm
Default Re: PT cruiser common problems?
Most common
Lower control arm bushings
Swaybar bushings and links.
Wattslink Bellcrank *rear end in the center of the axle if you have a drum brake setup*
and.........thats about it lol
ENJOY! that was a STEAL at that price
Old 26 Jan 2013, 11:06 pm
needmoretoys's Avatar
Oil pressure sender. like mine. Welcome to the forum Frank.
Lenny
FEBRUARY CRUISER OF THE MONTH
Old 27 Jan 2013, 08:05 am
VNT's Avatar
VNT VNT is offline
are you talking PM things you should do?
Plugs, wires, air filter.
Change coolant, change Power steering fluid, bleed brakes. Change trans filter and fluid.
Check suspension, clean battery posts and grounds.
Busted_PT likes this.
VNT
00 Durango SLT+ 5.9 4x4
02 Grand Cherokee 4.7 4x4
05 PT GT Silver 5 Spd Conv
17 Challenger SRT A8 GoMango
18 JL Wrangler Sahara Punkn
Old 27 Jan 2013, 03:55 pm
Originally Posted by Frank_ View Post
best squick ?? !!
I think that's BELT SQUEAK?
If it stops after engine warms up, that's fairly common and means belts are tired.
Old 27 Jan 2013, 05:00 pm
thanks for all the replies i have new plugs, wires and everything is real clean in the engine area. ill get a compete fluid change and go from there. i also have new belts so maybe ill thorw those on if they seem worn. i havnt drivin much yet but i will send it though its paces
Old 27 Jan 2013, 05:02 pm
mityqwik's Avatar
Thumbs up Re: PT cruiser common problems?
welcome to the forum and from virginia. Also !!!MOTOR MOUNTS!!!
It takes 8,460 bolts to assemble an automobile,
and one nut to scatter it all over the road
Old 27 Jan 2013, 05:07 pm
high and low fan
Old 27 Jan 2013, 05:18 pm
cruserdad1976's Avatar
frank man you should just go ahead and sell her to me ill give you your money back that way you wont have no worries
like all have said great deal and good luck
Old 27 Jan 2013, 05:44 pm
Check out the LCA bushings.
Also, ONLY ATF+4 in the trans and ONLY HOAT coolant (Zerex GO-5) in the radiator when you do your fluid changes.
VNT likes this.
First cruiser, need advice, common problems dom92 General PT Cruiser Discussions 18 28 Jun 2016 02:57 pm
2003 PT Cruiser Cruiser AC Problems PTCruisers Tech & Performance Forum 12 23 May 2015 12:43 pm
2001 Special Edition PT - Common Problems? RMO87 Tech & Performance Forum 9 10 Jan 2012 11:31 am
What are the common problems with 02 PTs. Looking at one to buy. twilightcall General PT Cruiser Discussions 1 01 Sep 2010 02:58 pm
Problems with my cruiser morrisbeer General PT Cruiser Discussions 3 25 Apr 2009 07:52 pm
