transmission issue??
Like Tree2Likes
  • 2 Post By mdskinner731
Old 27 Jan 2013, 11:31 am
mdskinner731's Avatar
Default transmission issue??
01 pt just rolled 175xxx miles. driving along it kicked into like neutral then slammed into gear. now it only kicks into gear when i get the RPM above 2500 then slams into gear. transmission fluid is still bright red. seems to be ok (maybe a little low but shouldnt cause an issue)
and if it matters the temperature was a frigid -12 degrees this morning.
if it moves and not supposed to... duct tape!!!
if it dont move and is supposed to... WD-40!!!
~* the problem with america is warning labels.... take them off of every thing and eventually the stupid people will die off... *~
Old 27 Jan 2013, 01:02 pm
VNT's Avatar
VNT VNT is offline
Default Re: transmission issue??
Get codes read, check fluid level.
Service history?
maybe a speed distance sensor or wiring to the TCM?
VNT
00 Durango SLT+ 5.9 4x4
02 Grand Cherokee 4.7 4x4
05 PT GT Silver 5 Spd Conv
17 Challenger SRT A8 GoMango
18 JL Wrangler Sahara Punkn
Old 27 Jan 2013, 02:51 pm
How many miles sense trans fluid and filter change?
Old 27 Jan 2013, 04:40 pm
all fixed. one of the lines from the cooler to the tranny was split. drained the rest of fluid and topped it off!!
Busted_PT and Slowrider like this.
Old 07 Feb 2013, 10:35 am
Send a message via Yahoo to Jtwheels2007
Im having this same problem as of this morning with my 2005. I put it into gear, and it doesnt MOVE AN INCH until i practically stomp the gas. as im driving it seams to neutralize for a few seconds, and then catches gear again. pulled back up into my drive way, and put it in park. let it sit a moment and put it into gear. it rolled BACKWARDS several inches before ever catching gear to keep it from moving back. I am unsure as to when the trans fluid was changed last. at what mileage should it be changed. I am sitting at 94,000 as of right now.
Old 07 Feb 2013, 11:17 am
MY book says change the fluid and filter at 48,000 miles (77000 km). Did mine at 50 and 100,000 miles.
Old 08 Feb 2013, 01:16 pm
trans fluid is fine. It is still red, and full. When this occured, engine light came on. Had code read, and it came back TCM *transmission control module* so far I have had no luck finding one.
Old 17 Mar 2013, 08:03 pm
Surprisingly, Had transmission serviced. Runs great again. transmission filter was extremely clogged *thick black material caked to filter* very MINIMAL metal on magnet inside transmission pan *which I was told will be there at ALL times* is there still a chance that transmission will fail again given the fact it clogged up so bad and the metal?
Old 18 Mar 2013, 03:19 am
The 'thick black material' was probably the clutches wearing due to low oil pressure due to a clogged filter. I would change oil and filter in 5000 miles just to see if there is wear still occuring. ATF +4 ONLY.
Does this sound like a transmission issue? sscanlan Tech & Performance Forum 7 12 Nov 2011 06:48 pm
Transmission Issue Need Help !!! newpt4me Tech & Performance Forum 5 13 Aug 2011 09:49 am
Transmission Issue Dhycin Tech & Performance Forum 4 15 Jun 2010 04:23 pm
Transmission Issue? extski Tech & Performance Forum 4 05 Jul 2009 01:15 am
Transmission issue... MDCruiser Tech & Performance Forum 10 06 Mar 2006 08:14 pm
