03 non turbo engine replacement
Old 06 Feb 2013, 01:30 pm
Default 03 non turbo engine replacement
New to forum, I just purchased 03 non turbo that probably needs engine.What are my options for replacement? My junkyard says hollander states only 03 fits. I know you pt gurus have the skinny on this. Thank you, Barry
Old 07 Feb 2013, 03:17 pm
UptownSport's Avatar
Default Re: 03 non turbo engine replacement
'03 and up, methinks.
There's an article "Rebuilding the 2.4" somewhere in my signature's links.
Are SURE it needs an entire engine?????????????
Old 07 Feb 2013, 08:50 pm
Not sure yet. Timing belt gone and water in radiator. -27 in michigan. Block is probably cracked. Gettin conflicting answers on what will fit.?????
Old 08 Feb 2013, 09:30 pm
i believe its 03-07 will fit. but make sure if getting one from salvage yard that you are getting a turbo motor or you will blow the bottom end out of it with boost
Old 08 Feb 2013, 09:44 pm
His is a non turbo.
2001 PT - Engine mount replacement needed with Oil pan replacement? SanPT Tech & Performance Forum 14 23 Sep 2012 08:49 pm
Engine replacement harrym Tech & Performance Forum 14 22 Aug 2012 12:55 pm
'03 Engine Replacement HiHo Tech & Performance Forum 4 21 May 2011 11:02 pm
Lower Radiator Hose Replacement on Turbo Engine paulb39 General PT Cruiser Discussions 7 09 Oct 2009 05:52 pm
Turbo Engine Replacement Bigphil3232 General Turbo Discussions 9 17 Nov 2004 05:43 am
