Testing a Computer on a PT
  • 1 Post By NitroPT
Old 06 Feb 2013, 08:03 pm
Default Testing a Computer on a PT
Any one know if the PT PCM can be tested before just buying one?
Old 06 Feb 2013, 08:08 pm
fy9-03pt's Avatar
Default Re: Testing a Computer on a PT
Have you tried the dealer or just a repair shop ?oops What is it doing ?or won't it start
Robert
Old 06 Feb 2013, 08:29 pm
Cant get a straight answer from a repair shop or dealer. No start no communication with a scan tool. Tried lots of other things. Pretty sure it is PCM but would like to test first.
Old 07 Feb 2013, 03:39 pm
You can't test the PCM if you don't have any communication with it. The only thing you can try is checking the wiring to the black connector for power and grounds. If all you wiring is good, and you cannot communicate with the PCM, you need to replace it.
-Chris
Old 07 Feb 2013, 08:49 pm
If you do the "key trick" do you get "done"?
If not, I'd sure say your PCM is toast.
Old 07 Feb 2013, 11:13 pm
no response on the key trick guess I will bite the bullet
Old 08 Feb 2013, 12:04 am
The "key dance" trick does not determine a faulty ECU. If the scan tool is in the ECU port access correctly and no damage to the port with a no communication readout the ECU has a problem which can not be resolved without removing it and examine by qualified OEM ECU Technician with proper diagnostic tools for this or a shop that provides this service.
We get DOA ECU occasionally and choose to replace them as opposed to a diagnostic check because of the expense to the customer.
If the ignition switch has wear ( which most due) on the contacts the "key Dance" will not work effectively for even viewing codes. It has always been a very primitive way to diagnose anything on any vehicles produced from 2000 and up using that method.
mityqwik likes this.
computer chip or after market computer?? mdskinner731 Tech & Performance Forum 3 08 Nov 2011 02:08 pm
testing CREWZIN Testing 0 19 Jul 2010 03:04 pm
testing sig. budrzgt Testing 8 20 Nov 2004 07:33 pm
testing 123 dev Testing 9 23 Jan 2004 12:18 pm
