Dead Battery in Key
Old 07 Feb 2013, 11:05 pm
Default Dead Battery in Key
Kinda a repost from another issue of my "PT DIED" I only have one key for the PT. I changed the Ign switch and acutator but not the key cylinder. If the key "battery" is bad will it not crank the motor. All I get is lights turn on but no crank. Trying to determine if it is the PCM or I need to replace the key cylinder as it may not comunicate with the car if the (key battery) is dead?
Thx for your help
Old 08 Feb 2013, 02:52 am
Ray_Dockrey's Avatar
Default Re: Dead Battery in Key
If the car doesn't recognize the key it will still start but die within a few seconds.
Old 08 Feb 2013, 07:16 am
If it's the key with the grey end on it, there's no battery inside, just a chip.
Old 08 Feb 2013, 07:57 am
If your key has a battery, it is for the remote keyless entry...it has nothing to do with starting and ignition. A transponder key, like the one in the pic posted by Crewzin, has no battery. It has a non-volitile memory so it doesn't need a constant keep-alive voltage. It is powered by the electromagnetic field generated by the coil around the ignition lock.
Old 08 Feb 2013, 08:05 am
As the others have said your key is fine. You may have a bad starter or some bad connections on they cables. Clean they big ground on the inner finder as well all the other cable ends.
Old 08 Feb 2013, 02:02 pm
If you have a post 2006 model with keyless entry, then you have a battery inside your key, but as stated already, it doesn't affect starting.
You may very well have a bad PCM, which is very common, but it is not related to your key, and there's no reason to replace the tumbler (key cylinder).
-Chris
Dead Battery???? I think not... cruisergeo Tech & Performance Forum 12 02 Sep 2016 04:32 pm
Battery going dead ew55 General PT Cruiser Discussions 1 14 Nov 2012 04:15 pm
Dead Battery??? Afitch628 Tech & Performance Forum 3 26 May 2011 09:09 pm
Dead Battery? dveldt Tech & Performance Forum 10 28 May 2010 04:59 pm
Dead battery at 33K miles sawdust123 General Turbo Discussions 14 16 Dec 2005 05:56 pm
