Rear Lights Out
Old 10 Feb 2013, 05:09 pm
Default Rear Lights Out
Excepting when I lock the car with my RKE, my rear tail lights are out. This includes the rear turn signals.
Replacing the tail light fuse in the fuse box under the hood fixed the problem about two months ago but I did not have luck doing so this time.
I have a 2001 "Limited Edition".
Old 11 Feb 2013, 12:48 pm
Default Re: Rear Lights Out
After replacing the fuse under the hood (defective fuse), turn signals are working. Tail lights light up when turned on but the brake lights are still not functioning.
Old 11 Feb 2013, 05:52 pm
Brake light switch might be out of adjustment.
Old 11 Feb 2013, 07:35 pm
Keeping in mind that the rear tail and brake light bulbs are double filament bulbs and half of the bulb can fail.
You likely replaced fuse #19 in the PDC.
Working back toward the battery, the brake light system consists of the grounds, the bulbs, the brake light switch, fuse #12 (15amp) in the PDC under hood, battery.
Also check dash fuses #2 (15amp), parking lights & #15 (20amp), flasher system.
Tags
2001, fuse, tail lights, turn signals
Rear Running Lights out.....need help turbotom General PT Cruiser Discussions 13 10 Mar 2012 04:11 pm
rear brake lights jacquit General PT Cruiser Discussions 1 23 Nov 2009 03:19 pm
Aftermarket rear lights careyk Classifieds: Want To Buy 2 10 Apr 2008 11:00 pm
Red Rear Turn lights Crash Exterior Accessories Forum 7 11 Oct 2001 04:28 am
