Water Pumps
Old 11 Feb 2013, 11:30 am
Default Water Pumps
So how many people have used this water pump? Any problems? How many miles do you have on the pump so far? AIRTEX #AW7167 from RockAuto. RockAuto Parts Catalog .. It has a 12month/12000 warranty.. I can get one made by GMB at Advance for $60 with a lifetime warranty..Has anybody used the one from Advance? The OEM local is $103.00
Old 11 Feb 2013, 12:14 pm
Default Re: Water Pumps
I have used and installed dozens sold hundreds of AIRTEX 20+plus years and GMB over 30+plus years. They are both good choices to go with. On my current PT AIRTEX #AW7167.
Funny you mention these 2 particular brands...
I just happen to have them both!
AIRTEX #AW7167
Old 11 Feb 2013, 12:15 pm
Gremlin's Avatar
Sorry, can't say I used the pump. I used a Gates pump (kit, with timing belt, etc.) when I replaced mine.
Just FYI, Rockauto has a coupon code for 5% off (code: 1266296310214368 in "How Did You Hear About Us" box), which may help.
White '03 GT. Mine since 2010. DIY work (read, budget): DIY cabin air filter, ball joint/control arm bushings/wheel bearing replacement, CV axle replacement, brakes, struts, K&N drop-in filter, oil pressure sensor replacement, Spark plug gasket replacement.
"But I don't want to go among mad people! Alice remarked. Oh you can't help that, said the cat, We're all mad here. You're mad, I'm mad. How do you know I'm mad? asked Alice. You have to be, or you wouldn't have come here, replied the cat."
Old 11 Feb 2013, 04:03 pm
Thanks for the pics. I believe I'm gonna go with the Airtex AW7167 and the Gates TCK265ARB kit..Does the water pump come with the gasket or is that something I need to pick up?
Old 11 Feb 2013, 04:04 pm
How many miles?
Old 11 Feb 2013, 06:21 pm
It comes with a new seal. Look in the box to be sure that it is there.
Old 11 Feb 2013, 06:47 pm
the GMB looks to be built a little better internally to me :-)
Old 11 Feb 2013, 08:15 pm
I wonder why the impeller is different on the GMB.. Less/more water flow? I also plan on replacing the crank and camshaft seals why I'm in there..They are not leaking but I'm going to replace them anyway.. Should I get factory seals, or just go to Advance or Autozone?
Old 11 Feb 2013, 09:55 pm
On the seals, call around and see who is cheapest. Far as the pump. The steel impeller is a n/a pump. The other is a turbo pump.
Old 11 Feb 2013, 10:28 pm
Well, that explains that.. I'm probably being picky on the seals.I just don't want to have to do it twice..I might try to go OEM if they are not to expensive..
DIFFERENCES IN WATER PUMPS? Busted_PT General PT Cruiser Discussions 20 19 Nov 2012 09:14 pm
water neck for the water pump Boxerjl2 Classifieds: For Sale/Trade 3 31 Jan 2008 02:48 am
PT Under Water CREWZIN General PT Cruiser Discussions 3 16 Jul 2005 02:50 am
