stuck in limp mode
Old 12 Feb 2013, 11:57 pm
Default stuck in limp mode
My 2006 pt has gone into limp mode with a check engine light
I've checked the code on the dash and got p0340 which points to the camshaft position sensor, but I'm not so sure. Im hoping someone here can confirm that replacing the sensor is the next logical step, or point me in a better direction if its not.
I'm having doubt because the car still runs but other topics on this forum seem to indicate that if the sensor were really not working the car wouldn't run?
Also after checking the code on the dash a couple times in a row it ceased to show me any code, still having the check engine light and still starting into limp mode.
Also can you tell confirm that hard starting is a part of limp mode or is that a symptom of the real problem?
Old 13 Feb 2013, 12:50 am
Chriscokid's Avatar
Default Re: stuck in limp mode
I just changed mine on 05 gt. when mine first went into limp mode, I took neg battery cable for five minutes to reset it and the vehicle returned to normal for awhile.
When problem returned, I ordered mopar oe online and changed myself.
Problem solved.
There's a good video on YouTube that shows how to do it. Takes about 30 minutes or less.
Let us know how it works out.
[SIGPIC][/SIGPIC]2005 PT GT Vert
2004 Honda Aquatrax turbo Jetski
2006 Honda Aquatrax
1998 Dolphin 36' motor home
1949 Piper Clipper taildragger
Old 13 Feb 2013, 06:16 am
Well the code does not necessarily mean that the sensor is "dead" .
Its just a trouble code telling you that the sensor is not working correctly.
I would order a new one personally. But BUY IT FROM THE DEALER. Get a OEM part.
DO NOT. I repeat DO NOT. buy one from advance, autozone or pep boys or your car probably wont leave the parking lot.
PTs are very picky and usually only run on OEM sensors and vomit up aftermarket before they even taste them.
Rough starting and idling can both be symptoms of a bad sensor :-)
Old 13 Feb 2013, 07:44 am
Thanks for the info guys, although I can't say I'm altogether relieved yet.
Also I can't say that the vehicle idles particularly rough, starting is hard in that I have to crank the engine 3 times as long as I normally do, but after 8-10 seconds of cranking it fires up consistantly and stays running just fine at least from idle speed til about 2200rpm where limp mode kicks in.
Tags
limp mode, p0340
Limp Mode? Bentron General PT Cruiser Discussions 23 21 Jun 2016 10:54 am
help..limp mode ivynthemnts758 Tech & Performance Forum 2 09 Sep 2010 08:44 am
Stuck in limp mode. Cleared some codes, but... SRT8guy General PT Cruiser Discussions 2 30 Jul 2010 07:15 am
01 cruiser in limp mode mui5m General PT Cruiser Discussions 1 04 Dec 2009 02:19 pm
Engine overheating, Stuck in "Limp mode" showing codes 0188,1490,&1495 Manny Tech & Performance Forum 4 08 Apr 2009 05:39 am
