Nitro
Old 13 Feb 2013, 02:32 am
Lightbulb Nitro
Have you used your trinity to measure your 0-60?
I haven't , i really baby it, but am curious
All I am running is the 93 tune
I wish it measured the lateral g's like the ol gtechs used to do.
I am wondering what my lateral g's are now.
Old 13 Feb 2013, 10:14 am
Default Re: Nitro
come on... floor it. just once. what's the worst that could happen?
Old 13 Feb 2013, 10:16 am
Default Re: Nitro
^^^^^ - pictures nitro out front of his house doing holeshots, adjusting air pressure, and repeating.
my guess is 6.3 seconds. anyone else have a guess before we get a real number?
Old 13 Feb 2013, 11:57 am
Default Re: Nitro
Not as yet. I did do a informational engine run up to see what the *93tune was capable of. At this point I have not taken interest in doing acceleration or skid pad data acquiring. I am not up to the point of making any suspension changes yet. Besides at this stage my results will be much different then yours. In the power range I am pretty sure that I am higher then yours ( you baby your PTwhich effects the output over time) which means traction permitting my 0-60 will be quicker. The lateral g readings may come close because I run a rear sway bar on stock suspension while you run the stiffer springs and lowered beyond reasonable handling limits of the suspension design. A stiffer suspension does not mean better handling! That comparison even within my own PT would be of interest to compare the before after I change to my target of suspension improved handling characteristic's.
One thing I have already done compared a few things with the DST and the Ultragauge. I was pleased to see that the Ultragauge is almost exactly the same as the DST. Makes it easier because I have my Ultragauge dash mounted and use it all the time.
He would need to aggressively change his driving habits for a few days so that the ECU could adjust changes enhancing the engines output
I do have the perfect street to do it on. No one parks in the street and there are no dogs off leashes and kids chasing balls!
*the Diablosport 93tune was badly named because it is presumed that you must run 93+ plus octane to use it, which is not the case at all! It shows how many un-experienced with ECU mapping and data logging have given mis-information about it!
Nitro's PT Cruiser NitroPT Members PT Project 1441 06 Dec 2018 01:55 pm
2010 Canadian Nitro Nationals at Toronto Motorsports Park TMPracing Canada PT Forum 0 16 Jun 2010 02:58 pm
