Will not start click click driver window goes down
  • 1 Post By CREWZIN
Old 14 Feb 2013, 09:16 am
Default Will not start click click driver window goes down
2006 PT vert. Turn key and get several clicking sound from driver side on fire wall at what looks like 1inch square relay,s. two furthest to driver side. Starter clicks and driver window moves down one uncheck with each start try. Battery is new.
Old 14 Feb 2013, 09:50 am
Default Re: Will not start click click driver window goes down
Check all the connections on the cables. Not just the one on the battery. There should be a big ground on the driver send inner finder behind the filter box. Clean all the connections all the way to the end of both wires. If that doesn't work. Tap the starter on the side while someone turns the key. If that works you need a starter.
Old 14 Feb 2013, 10:04 am
Will try all that and see. Do not understand why driver window goes down when trying to start, wipers sometimes make one cycle or radio turns on, all when trying to start. What are the little 1inch boxes on fire wall, dr side up high. They click repeadly when holding key to start?
Old 14 Feb 2013, 10:12 am
These cars do weird things on low voltage. A bad ground can cause this condition. But the computer is a possibility.
Old 14 Feb 2013, 11:38 am
On convertibles, the drivers widow goes down an inch to allow the door to close (open ??) without pinching/pulling on the rag top. The top overlaps the window and going down an inch or two allows the door to open/close smoothly. That how it works on some cars and probably the PT. Why your is doing it at the present time might have something to do with the switch/sensor seeing a signal from the ignition switch.
I've heard of owners resetting the computer to fix that problem. Take off the negative battery cable off for about 5 minutes.
Did the person putting the new battery in clean everything? Take Busted's advise and check on the connections.
Fe2orr likes this.
Old 19 Feb 2013, 05:12 pm
Cleaned everything I could find and tightened all. Car starts ok for now. Have lost currant to pass side front and driver side rear turn signals both bulbs are good. Fix one thing and another shows up????
back seats don't click into place... puddingmobile PT Cruiser Convertible Forum 8 31 Jul 2008 09:50 am
Click Click jmack General PT Cruiser Discussions 3 13 Mar 2005 03:53 pm
DO NOT CLICK THIS!!!! THier Testing 5 25 Jun 2004 10:32 am
Click in steering column tcruiser General PT Cruiser Discussions 3 11 Nov 2002 12:25 am
