Can I swap a 2001 w/egr engine for a 2002 engine w/o egr?
Old 15 Feb 2013, 12:07 pm
Question Can I swap a 2001 w/egr engine for a 2002 engine w/o egr?
I have a 2001 PT limited edition, 4dr, automatic with EGR. I need a new engine. Can I swap mine for a 2001 or 2002 engine that doesn't have EGR? Will it need modifications?
Old 15 Feb 2013, 12:14 pm
Default Re: Can I swap a 2001 w/egr engine for a 2002 engine w/o egr?
The big thing is the crank sensor location on the block. They have to be in the same location.
Old 15 Feb 2013, 01:51 pm
my 2002 has EGR. same as the 2001.
just out of curiosity, why do you need a new engine?
Old 15 Feb 2013, 02:20 pm
rcktpwrd's Avatar
'01 and '02 had egr, in '03 Chrysler did away with it. The engines will swap provided the sensors are in the same place like mentioned above. The other issue is that the '01 computer will still be looking for the egr so you will have a check engine light...
Joel
Old 15 Feb 2013, 02:28 pm
The 03 won't go in because of the crank sensor is in a different location. 02 I'm not sure about them. Also they can drill for the egr.
Old 15 Feb 2013, 11:58 pm
UptownSport's Avatar
Yes, the acronym 'NGC' (Next Generation Controller) applies to '03 and up PT's.
The crankshaft ring thingy the computer reads is different '94-'02 and '03 & up.
Some less popular vehicles (Jeep?) didn't go to NGC in '03, so just do as Busted says to differentiate.
Chrysler also sells head EGR blocks offs, PN 4591227
I have used ones; drill down in this link:
drive089 | eBay
2001 Engine swap mastifffreak Tech & Performance Forum 19 18 Feb 2014 10:35 am
Engine swap 2001 to 2007 boerter Tech & Performance Forum 7 16 Feb 2014 11:08 am
2001 Engine and parts swap out. anneslimo Tech & Performance Forum 11 18 Jan 2013 05:38 pm
2002 PT Cruiser Engine Swap TurboDucky Tech & Performance Forum 7 11 Jun 2011 11:45 am
2002 Engine swap sporthog93 Tech & Performance Forum 2 08 Apr 2011 02:31 pm
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
