fault code p1648
Old 17 Feb 2013, 12:45 pm
Mickey_Knox's Avatar
Default fault code p1684
Anyone got any info on this code? All I could find on it was a battery control module or motor control module? Could it also be the tcm cause it has started doing a hard downshift from 2nd to 1st.
Old 19 Feb 2013, 06:40 pm
Default Re: fault code p1648
P1684-BATTERY WAS DISCONNECTED
When Monitored: Whenever the ignition is in the Run/Start position.
Set Condition: This DTC is set whenever the Transmission Control Module (TCM) is disconnected from battery power (B+) or ground. It will also be set during the DRBIII Quick Battery Disconnect procedure. Note: Due to the integration of the Powertrain and Transmission Control Modules, the transmission part of the PCM has its own specific power and ground circuits.
-Chris
Fault Code P0243 Help!!! bibble Tech & Performance Forum 5 17 Sep 2012 05:37 pm
fault code flourman Feedback and Support 2 06 Mar 2011 08:10 am
Still getting a P0304 Fault Code????? caballero77 Tech & Performance Forum 14 01 Feb 2011 08:31 pm
PO121 fault code forcedinduction Turbo Performance 3 14 Feb 2006 12:14 pm
Fault code RossiePT General Turbo Discussions 8 28 Mar 2004 10:52 pm
