Turn signal activates signal...and wipers?
Old 18 Feb 2013, 12:46 pm
TF3 TF3 is offline
Default Turn signal activates signal...and wipers?
Hi, new to the site! I have a 2008 Cruiser and have encountered several electrical problems. For this first post, I'll ask about the most recent, which happens to require the most immediate attention.
When I activate my turn signal (usually the left more than the right), the turn signal works, BUT for some reason my wipers are activated too...? The wiper stalk is on the right side, while the blinker/headlights stalk is on the left, so the wipers shouldn't be activated at all. Is there a relay between the two stalks that might be getting things crossed? Or does it sound like I either need to switch out the turn signal/headlight stalk or both signal/headlight & wiper stalks? Or the entire switch? Thanks in advance for any suggestions.
Old 18 Feb 2013, 04:31 pm
Default Re: Turn signal activates signal...and wipers?
Both stalks are tied together. Sounds like wires are crossed somewhere.
Old 19 Feb 2013, 12:48 pm
TF3 TF3 is offline
Definitely sounds like something between both stalks. But to add a bit of inconsistency to the issue, it didn't do it at all either last night returning home from work or this morning's drive back to work...? I'd consider weather factors (expansion/contraction), except it's been in the 50-60 range for the past two days. Could there still be something arching internally? Puzzling...
Windshield Wipers Turn On With Turn Signal or Bump... NewPTCruiserInPA General PT Cruiser Discussions 8 17 Dec 2013 09:10 am
Headlight, Wipers, Turn Signal, Accessory Lights greasdawg General PT Cruiser Discussions 4 20 Jul 2011 12:01 pm
headlight/turn signal/wipers wiring enigma wheresmarko General PT Cruiser Discussions 2 01 Jul 2011 06:15 pm
Turn Signal jmack General PT Cruiser Discussions 5 12 Apr 2005 11:57 am
blue turn signal bulbs that turn orange when in us Capt Kidd General PT Cruiser Discussions 1 04 Jun 2004 10:10 pm
