NO BUS AND GAUGES ARE NOT WORKING!!!
Old 18 Feb 2013, 06:17 pm
Default NO BUS AND GAUGES ARE NOT WORKING!!!
Guys please help I just did the motor mount on my car started it up and i get the no bus my airbag check engine and brake light are on!
03 Pt 5spd and lovin it!
Old 18 Feb 2013, 07:04 pm
Default Re: NO BUS AND GAUGES ARE NOT WORKING!!!
Something to read...
No Bus
Old 18 Feb 2013, 07:07 pm
No Bus
Problem is that i have checked all my fuses took my dash apart and checked everything. This car is really starting to become a headache one thing after another.
Old 18 Feb 2013, 07:14 pm
Have seen this on Jeep Cherokees...Engine won't start, "no buss" displayed on the odometer, and guages not working...the cause is a bad CPS (crank position sensor). A relatively common problem on Cherokees but not sure how it may relate to the PT.
The No#17 (IOD) fuse in the engine compartment is really hard to tell if it's bad.
Old 18 Feb 2013, 07:42 pm
I replaced it! And still same problem
Old 19 Feb 2013, 06:36 pm
Can you get the check engine light code?
-Chris
Old 19 Feb 2013, 07:15 pm
VNT's Avatar
VNT VNT is offline
So you changed a motor mount and then the problem showed up?
Did you do anything to the electrical, disconnect anything or inadvertantly do something to the wiring?
No bus usually means toast PCM or BCM?
I would disconnect the battery and then reconnect it.
VNT
00 Durango SLT+ 5.9 4x4
02 Grand Cherokee 4.7 4x4
05 PT GT Silver 5 Spd Conv
17 Challenger SRT A8 GoMango
18 JL Wrangler Sahara Punkn
Old 20 Feb 2013, 11:00 am
It could also be a bad instrument cluster, or the connection between the cluster and PCM.
-Chris
Old 20 Feb 2013, 11:14 am
Hey already fixed the problem it was a lose battery cable.
Sometimes things are just simple!
In any situation specifically on an computer control vehicle that the gauges go wacky always look for the battery and the connections first.
gauges not working prpldancer08 Tech & Performance Forum 1 03 Oct 2012 04:29 am
Dash Gauges/Needles Stop Working Bigdaddy_1106 Tech & Performance Forum 2 01 Jul 2011 08:13 am
Gauges, A/C and Power Locks Stopped Working khorak Tech & Performance Forum 3 12 Jul 2010 09:43 am
What three gauges? 340X2C Tech & Performance Forum 2 06 Nov 2008 07:43 pm
Add-on Gauges Help 2K1Cruizer Tech & Performance Forum 2 03 Dec 2001 07:42 pm
