Won't start 2003 non turbo
Old 28 Feb 2013, 02:39 pm
Default Won't start 2003 non turbo
The water pump was leaking so, I replaced it along with the timing belt, pully and tensioner. I get a code of 0016. I made sure the cam sensor was plugged in. The cams and crank marks are lined up. I put a link of the pictures below. It sounds like it wants to start but won't. I read hear the left cam sprocket should be a half a tooth lower? That's why I made sure it was. Any ideas on what else to check?
http://i1287.photobucket.com/albums/...ps48cd2e8e.jpg
http://i1287.photobucket.com/albums/...ps9f3ef34d.jpg
Old 28 Feb 2013, 05:19 pm
Default Re: Won't start 2003 non turbo
Ok, I noticed the gas guage was on empty. I put gas in it than the battery got too low to krank it over but, I don't have any error code anymore. I'm waiting for the battery to charge now. I sure hope I don't have to tear it down again to re-align the sprockets.
I was hopeing someone would look at the pictures and tell me what they think. Your edvise is shirley appreciated.
Lee
Old 28 Feb 2013, 05:28 pm
I'm now getting a 0522 code
Old 28 Feb 2013, 05:37 pm
Now a 0016 and a 0522. It almost seems I need to realign the timing.
Old 01 Mar 2013, 12:33 am
the cam timing marks are off less than one full notch. Therefore the crank must be turned in either direction to find true tdc. One way is to use a long dowel and a dial indicater in # one plug hole. A 2.4 sebring manual shows the crank timing mark on the left side of the sprocket tooth. More investigation is needed.
2003 PT Cruiser sometimes won't start walker1213 Tech & Performance Forum 2 21 Jan 2013 10:00 pm
2003 won't start after new plugs gwbolton Tech & Performance Forum 5 27 Dec 2012 10:05 am
2003 PT wont start.. vikz General PT Cruiser Discussions 1 04 Jan 2012 07:49 am
2003 pt won't start clsals Tech & Performance Forum 1 14 Jul 2011 08:57 am
2003 pt crusier wont start smith4384 General PT Cruiser Discussions 4 19 Jan 2009 02:27 pm
