P0334 Knock Sensor 2 Circuit Intermittent (Bank 2)
Old 04 Mar 2013, 06:59 pm
Default P0334 Knock Sensor 2 Circuit Intermittent (Bank 2)
I just change the plugs with champ double platinum and BWD Select Plug Wires, And change the oil pressure sensor and the PVC valve. And now I am getting this code P0334 Knock Sensor 2 Circuit Intermittent (Bank 2)
what does this mean ? knock sensor is bad? Or the wiring bad ? Any help would be appreciated
Old 04 Mar 2013, 07:00 pm
Default Re: P0334 Knock Sensor 2 Circuit Intermittent (Bank 2)
I forgot it is a 2003 non turbo 2.4L
Old 04 Mar 2013, 07:32 pm
Ray_Dockrey's Avatar
Sounds like maybe in all your work you may have knocked something loose.
Old 04 Mar 2013, 07:53 pm
The knock sensor is located on the front side of the cylinder block near the starter.
Check the wiring and the electrical connection
Old 04 Mar 2013, 08:04 pm
Ok thanks for the help. I will have to look tomorrow am at work now will post update
Error Code: P0325 PCM Knock Sensor Circuit tcr1016 Tech & Performance Forum 17 07 Jun 2011 12:40 pm
PCM Knock Sensor Circuit?????? turbonate2003 General Turbo Discussions 11 19 May 2011 06:52 pm
P0138 HO2S Circuit High Voltage Bank 1 Sensor 2? Samson Tech & Performance Forum 1 16 Jun 2010 04:47 pm
P0138 HO2S Circuit High Voltage Bank 1 Sensor 2 ptlvr Tech & Performance Forum 8 09 Aug 2008 10:13 am
error code p0325 pcm knock sensor circuit? madchildptgt Tech & Performance Forum 0 16 Feb 2007 06:16 pm
