Bad Ignition Cylinder Tumblers
Old 13 Mar 2013, 07:21 am
Default Bad Ignition Cylinder Tumblers
So this recently started to go bad. I managed to get into run position (or w/e it is) to remove it. I just removed the tumblers and put it back in.
My question is what concerns am I not thinking about by not having the tumblers in.
1. My car has alarm system so you need the push button to disable it. Even if you open car with correct key/start it alarm stays on (i know i did this by accident once, opened car with key not push button thing, started it thinking that would disable alarm, nope have to push the button).
2. My car will start with any key but will shut down after 1 second if they key in the ignition isn't the one with the chip inside.
So with that info what am I missing by not paying $60 for a new cylinder with tumblers (btw If anyone knows of a place where you can just get the springs for inside and/or tumblers without paying for a whole knew cylinder) and just leaving the tumblers out.
(Yes I know you can remove key while car is running, doesn't bother me.).
Old 13 Mar 2013, 08:32 am
Default Re: Bad Ignition Cylinder Tumblers
Have you checked eBay for this part?my thinking is try locking manually. And trytthe key.
Old 13 Mar 2013, 01:26 pm
Nah I know i can buy off ebay. I was just wondering if i wasn't thinking of a downfall by not having tumblers in the ignition.
Old 13 Mar 2013, 03:53 pm
i never removed the tumblers before, but i always yank the key out when i get a new car. i don't have the key with the chip, and i like being able to take the key out with it running. it's handy for starting it in the winter/leaving it running. i also take it out when i pick up a shady passenger so they can't turn my car off if i feel the need to crash it.
if it runs fine how it is and doesn't cause you any issues, i would just leave it alone.
get rid of the alarm if it's annoying you. all they do is piss people off and cause electrical problems down the road. if i wanted to steal a car with an alarm i'd just set it off a few times in the middle of the night and wait for you to turn it off for me.
Help - #4 Cylinder Missfire Kevhead General Turbo Discussions 3 21 Aug 2013 02:49 pm
Oil in my #1 Cylinder mikeyt89 Tech & Performance Forum 6 11 Sep 2012 03:22 pm
ignition cylinder jammed/broken? Jenn1709 Tech & Performance Forum 1 31 Jan 2011 11:11 pm
Need new ignition cylinder, if I keep old key will car still start? Smifo Tech & Performance Forum 7 28 Dec 2010 11:27 am
Replacing Ignition Lock Cylinder--Done Matt42 Tech & Performance Forum 2 20 May 2010 10:10 pm
