power assist not working on brakes
Old 13 Mar 2013, 08:43 am
Default power assist not working on brakes
When I went to leave a store my power assist had stopped working on my brakes....does any one have an idea where to start looking and what the most likely cause is!!
Old 13 Mar 2013, 09:10 am
Ray_Dockrey's Avatar
Default Re: power assist not working on brakes
Check to make sure the vacuum line is connected. If it is you can pull it to see if you are getting vacuum and if you are then the vacuum booster might have failed.
Old 13 Mar 2013, 09:16 am
Yes do as Ray says. Check all the big vac hoses, from the booster out to where they go. A hose could have split and fell off.
Old 13 Mar 2013, 03:56 pm
Is the idle high and jumping all around? That's just what happened to mine when the vacuum hose parted at a junction along with loosing the assist in braking. Check all the lines connected to the booster as was just mentioned above.
power mirrors not working ricksatluz Tech & Performance Forum 9 10 Dec 2012 04:59 am
2007PT Head/Brakes Working, Tailights Out PurplePT2007 General PT Cruiser Discussions 0 14 Apr 2012 12:16 pm
Overheating issue. Please assist! sjzdx Tech & Performance Forum 18 27 Jun 2011 08:16 pm
Power locks not working! JHCT General PT Cruiser Discussions 1 30 Nov 2008 04:03 pm
