Engine leak
Like Tree2Likes
Old 13 Mar 2013, 08:00 pm
Default Engine leak
Here is a video of my 01 pt. What do.you guys think it the cause?
Old 13 Mar 2013, 08:40 pm
Default Re: Engine leak
You video is not working for me. But if you are leaking from the back side of the engine. It most likely the oil sending sensor.
Old 13 Mar 2013, 08:55 pm
so how can this be fixed?
Old 13 Mar 2013, 09:30 pm
cruserdad1976's Avatar
if you mean how can the oil sending unit be fixed thats easy just change it its a little hassle to do but its not a big deal and its a cheap fix and you can say hey i did it
Busted_PT likes this.
Old 13 Mar 2013, 10:06 pm
^^^^^^ What dad said!
Old 13 Mar 2013, 10:15 pm
Old 14 Mar 2013, 07:15 am
OK how many miles and when did the leak start? Any oil lite blinking? Two biggest leakers are the oil pressure sending unit and valve cover. Both easy to do. EBay has the best deal on gaskets. Sender in my opinion can be aftermarket.AAfter all the OEM is notorious for failing. So aftermarket should be as good.
Motorhead likes this.
Old 14 Mar 2013, 01:46 pm
158k runs good so I don't plan on getting rid if it soon, no oil or engine light. It started I believe 2 months ago
Old 14 Mar 2013, 09:36 pm
UptownSport's Avatar
you can see green oil pressure switch connector at 55 seconds, and at various other moments.
Oil always rains down, and road draft blows it back
Old 14 Mar 2013, 10:40 pm
at around 22 seconds thats where its leaking right ? the oil pressure sensor?
Troubleshoot coolant leak: Photo of Coolant on top of engine radiator cap MarcusO Tech & Performance Forum 7 27 Apr 2013 09:16 am
Engine Oil Leak Ikster Tech & Performance Forum 2 01 Mar 2013 05:29 pm
Engine coolant leak help Vicky Tech & Performance Forum 9 25 Jul 2012 04:22 pm
Engine Oil Leak Ikster Tech & Performance Forum 9 30 Apr 2012 09:36 pm
Engine Oil Leak rcalzadilla Tech & Performance Forum 10 24 Sep 2009 08:25 pm
