key problems
Old 17 Mar 2013, 03:54 pm
Default key problems
Hi,
At first tonight my key would start the engine but then it just cut out, it now doesn't do anything , all the dashboard lights are on, just no response when the key is turned.
The recovery guy thinks its possibly an immobiliser issue , which i guess is connected to the key ?
Is this a common problem and would a new key sort it out ?
I have two keys for the car , the first one stopped working last Year so we have been using the spare ever since
Would like to hear your opinions
Old 17 Mar 2013, 03:59 pm
Ray_Dockrey's Avatar
Default Re: key problems
Normally if its the key it will start for a few seconds and then die. How old is your battery?
Old 17 Mar 2013, 04:06 pm
Yes this is what it did, The RAC guy said battery was a bit low, he tried to crank the car with a direct supply to the starter motor, but it wouldn't strike up, which is unusual for this car as it starts first time
Old 17 Mar 2013, 04:12 pm
I also noticed while being towed that 'no bus' was flashing on the dash ! what the hell does that mean ??
Old 17 Mar 2013, 04:20 pm
is it cranking? I just bought my PT and freaked out when I couldn't get it to start after putting in a new battery. I looked up problems and there is a think that won't let you turn the key all the way if the steering wheel isn't turned all the way to the right. I did that and it started.
I'm not sure if this is your problem but it's worth a shot. Put key in, turn steering wheel to the right as far as it will go then turn key to start.
Old 17 Mar 2013, 04:21 pm
No bus
No Bus
Old 18 Mar 2013, 04:27 am
just an update to this , I have just removed the IGN RUN fuse and the car started first time !
No Bus still flashing tho !
Old 18 Mar 2013, 12:47 pm
Try disconnecting the battery for 10 minutes.
This resets the ECU :-D may fix it, may not. but worth a shot :-D
Old 20 Mar 2013, 01:42 pm
I have found the problem, several cables had corroded in the wiring loom that passes in front of the rad, and were shorting out , I've split them up and repaired them, everything now running perfectly.
Well pleased !
Trev
Thanks for all your suggestions
Old 20 Mar 2013, 05:02 pm
PTJunkie's Avatar
AC problems Leannaluv Tech & Performance Forum 6 17 Jul 2011 08:22 pm
IOD Problems?? loneleix General PT Cruiser Discussions 4 21 Jun 2010 01:50 am
new guy here with problems tillerDave General PT Cruiser Discussions 2 13 Jun 2010 02:02 pm
More Sub Problems CHROMEDCRUISER Sound and Security Forum 7 17 Feb 2005 05:00 pm
i got 2 problems and i need ur help :( junkno Tech & Performance Forum 7 18 Dec 2004 11:24 am
