06 Engine Swap Question
Old 22 Mar 2013, 11:06 am
Red face 06 Engine Swap Question
We are in the process of swapping my 06 engine. We've followed all the instructions that we could find to just pull the engine out of the top. We seem to have everything disconnected, but can't get the engine and transmission completely seperated. It's about 1/2 inch gap now.... Is there any internal bolts that have to come out?
Any guidance would be greatly appreciated!
Old 22 Mar 2013, 02:15 pm
UptownSport's Avatar
Default Re: 06 Engine Swap Question
did you loosen driveplate / Flexplate bolts?
Old 22 Mar 2013, 04:46 pm
Red face Re: 06 Engine Swap Question
I'm a novice with this part, so please bare with me.....
Those are internal, right? I think that I can see them, are there 4?
Old 22 Mar 2013, 05:39 pm
cruserdad1976's Avatar
i think it is really suposed to come out the bottom btu the top will work just a tad bit more work
Old 22 Mar 2013, 06:55 pm
Take the inspection plate off of the bell housing (bottom front part of transmission), twist the motor around with a wrench on the crankshaft at the pulley (harmonic balancer), and remove the 4 flexplate bolts from the torque converter.
As a suggestion, paint one of the bolt holes along with the flexplate area with the bolt out, so you can line then up quickly during install. The bolt holes are staggered , so the flexplate only goes on one way.
Too many times you get to the fourth bolt to install, and it will not line up.
A still runnin' 01 Limited,,all with a little prayer, and a lotta elbow grease
Red tint tails, chrome trimmed grille, custom towel rack buttonless flamed shifter, auto dimming rear view, Homelink remote transmitter, driver seat drawer, MOPAR sub, lowered 1" rear, MOPAR/Borla dual tipped exhaust, chrome trimmed GT gauge/airbag surround, front 35% tint, and the ever so important Fuzzy Dice
Old 22 Mar 2013, 09:08 pm
Thanks!
I figured it out after your first post. Got it apart, now just have to figure out how to maneuver the engine out of the hole.
Really appreciate the advice!
2.4 engine swap krozby Tech & Performance Forum 15 11 Feb 2016 09:31 pm
Can I swap a 2001 w/egr engine for a 2002 engine w/o egr? cas0918 General PT Cruiser Discussions 5 15 Feb 2013 11:58 pm
engine swap question Wonderjava Tech & Performance Forum 11 16 Jun 2012 06:33 pm
2003 to 2007 Engine swap question luckybadazzboy Tech & Performance Forum 0 10 Sep 2010 08:47 pm
engine swap question jess82 Tech & Performance Forum 1 09 Apr 2010 03:51 pm
