Idle vibration, Let me see of I have this right
Old 23 Mar 2013, 09:24 am
Gru's Avatar
Gru Gru is offline
Default Idle vibration, Let me see of I have this right
I just picked up an 05 GT last night to replace the 02 5 speed I killed (still feel lousy about that). GT has 180K but it was a one owner car and the woman who owned it, brought it to the Chrysler dealer for everything. She even used all the little tear out pages in the maintenence book; stamped and signed. I had them put it on a lift and the underside looks like it never left the showroom.
Anyway, the only problem it has is a strong vibration at idle. Putting it in neutral or park lessens it but I can still feel it. So... from what I have read on here and drawing from my own personal experience it could be one of the following:
Mechanical: motor mount. Replace
Electrical: coil, wires, plugs. Replace
Fuel: injectors. Clean (In tank cleaner effective? Lucas?)
Air: vacuum leak, dirty tb. Search for leak, clean tb
I figure I will contact the dealer and see if any of these have been done recently to eliminate as a possibility.
Also, as an interesting note, when I test drove it, I was very dissapointed with the acceleration. I thought my n/a 02 5sp could keep up with it. It was just about on empty so they told me to go fill it up, on them. I filled it with premium and began wondering if they had filled it with regular. Sure enough, premium solved the performance problem. So, I was thinking maybe it had been sitting for a while at the place I bought it and maybe using reglar over a period of time had gummed things up. Possible? Anyway, I am going to try some Lucas and see if that helps. I don't have high hopes.
Any thoughts?
In case I don't see you...
Good afternoon, Good evening, and Good night.
Old 23 Mar 2013, 10:14 am
Default Re: Idle vibration, Let me see of I have this right
Check the simple stuff first...clean the throttle body, check for vacuum leaks, replace the pcv valve, check/replace the plugs. Fuel system cleaners in the tank are a waste of money. ...btw, the automatic is a slug compared to the 5 speed.
Old 23 Mar 2013, 10:33 am
Actually the injector cleaners are a good thing if you have a fuel issue. Done it many times. I don't use it every tank. Some do. Can't hurt to rule out that part. If the mounts have been replaced then maybe not set to the proper adjustment. Or like someone on here, were they put a standard shift mount on a auto. Check for a leak in the turbo boost hoses. You will loose a lot of power that way. No comparison to a n/a 5 speed. If it is right. If you know what your doing. The auto stick is no slug by any means.
Old 23 Mar 2013, 12:41 pm
Gru's Avatar
Gru Gru is offline
I have owned two early production 01 automatics from brand new, an 02 5sp (RIP), and now the 05 autostick. On the way home I was doing 70 and I mashed the accelerator down to pass a truck, and I believe the traction control actually kicked in for a second! I have never seen a slug do that.
Just to make sure I have all the vacuum lines covered, how many connections/zip ties am I looking for? Any photos or descriptions?
Old 23 Mar 2013, 12:48 pm
UwharriePT's Avatar
I am interested to see what you find out. El Diablo ( as my mechanic dubbed my car after the last visit) also has an idle vibration. Like yours only when in gear. I did not notice one before his last trip into the shop. But most likely that was because ED was missing a motor mount before
2002 Limited
Taupe Frost Metallic
Old 23 Mar 2013, 01:06 pm
Gru's Avatar
Gru Gru is offline
What/where is a torque strut?
Old 25 Mar 2013, 03:56 am
Are you getting any codes? The gt's will run on regular gas, but when the knock sensor goes off, the computer pulls back the timing to save the engine from damage. This results in lower power. The turbo guys know more than I.
Rough Idle-Replacing the IAC Idle Air Controller engineerrock Tech & Performance Forum 9 07 Jun 2014 07:24 pm
Idle vibration garner49 General Turbo Discussions 14 07 Apr 2013 09:48 pm
Motor Mounts Replaced Now Vibration at Idle falconut Tech & Performance Forum 12 15 Mar 2013 07:48 pm
Idle vibration... garner49 General Turbo Discussions 6 17 Nov 2009 06:40 pm
Vibration between 40 & 60 mph???? anyone had this? gtbright General Turbo Discussions 10 16 Jul 2005 03:06 pm
