2007 PT Cruiser convertible with 27k miles CHECK ENGINE.
Old 24 Mar 2013, 07:49 pm
Unhappy 2007 PT Cruiser convertible with 27k miles CHECK ENGINE.
Hello all, thank you for taking the time to read this as I am new here but am in a bit of a panic. Two days ago I purchased a 2007 PT Cruiser convertible with 27k miles on it. I test drove the vehicle and it was perfect, so I left my deposit on the vehicle. I purchased the vehicle a week later and made the 85 mile drive home with no problems at all. Now one day later the check engine light came on and stayed on (no flashing light, I know that would be a worse case scenario.) I obtained the P-codes and they are P0304, P0522, P0562, and P0700.
My vehicle is under warranty and I will be taking it in ASAP within the next week. I am by no means anything close to a mechanic, so I am nervously wondering if these codes reflect me having bought a lemon. I've read what each code means but that hasn't helped me much in knowing if anything is very serious here. I really hope not as this has been my dream car and I've finally found one with low miles and a clean carfax. Would I be ok driving it to work in the AM (26 mi.)? If anybody has any insight it'd be very much appreciated. Thank you, again.
-Matt
Old 24 Mar 2013, 08:08 pm
Default Re: 2007 PT Cruiser convertible with 27k miles CHECK ENGINE.
Welcome to the forum.
With such a random bunch of codes, it's hard to believe you have that many things wrong at the same time. You already know what they mean so won't go over that part.
My suggestion is to take the negative battery cable off for about 5 minutes. Step on the brake peddle to get rid any residual charge and then put it back together. (while the battery cable is off, check for any signs of corrosion around the cable or battery terminal and check the positive side also). Taking the cable off resets the computer and gets rid of any codes that might have been stored before you checked them. Now drive the car and see what, if any, codes come back up if the engine light comes back on.
Old 24 Mar 2013, 08:19 pm
Thank you, Crewzin. I was alarmed at the amount of codes and that they seemed all over the place, but the car is running fine. No jerking or idling, really smooth ride. I'll try what you said and report back.
Tags
check, engine
2007 PT Cruiser Check engine light and transmission problems. jpierce2087 Tech & Performance Forum 18 22 Oct 2015 08:30 pm
2007 pt cruiser rough idle with check engine light firstblackbelt2010 Tech & Performance Forum 1 01 Sep 2012 07:34 am
2007 Cruiser with 33,719 miles on....already has an oil leak??? xxcutetaraxx General PT Cruiser Discussions 11 26 Mar 2011 08:32 am
2003 PT Cruiser GT; 53K miles with check engine light; $2,000; Newport RI golddollarkid Classifieds: For Sale/Trade 3 25 Jun 2010 08:26 am
2007 PT Cruiser Convertible Amethyst Tech & Performance Forum 0 07 Oct 2009 07:24 am
