Battery
Old 25 Mar 2013, 04:01 pm
Exclamation Battery
So it started this Friday battery light came on for like a secOnd then went away when I got home for some reason I tried to lock the car nothing hit the remote nothing open the door dash was very dim tried to turn pt on nothing click now today driving to work when I turned the corner pt just shut off tried turning the key nothing open the hood shook the battery and cables boom turned right on. Now keep in mind I just installed a sound system as well as an aftermarket radio I don't think it's draining my battery because of it did I would of needed a jump what could this be my opinion is that either the cables are going bad or my alternator what do u guys think I need some help
Old 25 Mar 2013, 04:19 pm
cruserdad1976's Avatar
Default Re: Battery
if just shaking the cabvles worked then id have to say some kind of a loose conection check both ends clean them and make sure they are tight if the alt was going bad it would give you a light all the time
Old 25 Mar 2013, 04:21 pm
Default Re: Battery
i'm going with battery and/or cables. if you could shake things under the hood, check to make sure the cables are tight on the battery. pretty much rule out the alternator.
edit: what dad said. LOL
2016 Kia Soul Plus Black
Old 27 Mar 2013, 09:40 am
Default Re: Battery
Agreed.
You have your answer - shaking the cables brought things to life - tighten the cables!
Old 27 Mar 2013, 10:36 am
Default Re: Battery
Doesn't completely rule out the alt. If brushes are warn down they can give a intermittent charge or no charge ( light). You didn't give any milage. Overall I agree with above. Check All the cable connections not just the battery end.
Battery edscrz General PT Cruiser Discussions 8 20 Mar 2013 01:19 am
Is this my battery? azphotog Tech & Performance Forum 5 19 Aug 2012 11:44 pm
Battery in the key fob GTinAZ General PT Cruiser Discussions 15 12 Nov 2004 03:43 pm
battery twinturbo General Turbo Discussions 7 20 Mar 2004 05:49 pm
