Coolant leak at transmission line
  • 1 Post By ZZTOPT
Old 26 Mar 2013, 09:23 pm
Default Coolant leak at transmission line
I have a 2001 Limited with an antifreeze leak at the bottom driver's side of the radiator. As weird as this seems, the leak is coming from behind the transmission oil coolant line fitting closest to the radiator drain valve. If I pull out on the transmission line hose, antifreeze leaks from behind what seems to be a pressed fitting in the plastic section below the bottom seam of the radiator. The fitting has some play to it (when grasping the hose, it can be moved backwards and forwards about an 1/8"). It doesn't leak ATF, only antifreeze.
I've already replaced the radiator once a while back because of an unrelated issue, so I'm trying to avoid replacing it again if at all possible. Has anyone experienced this problem?
Old 26 Mar 2013, 10:09 pm
Default Re: Coolant leak at transmission line
Sounds like your trans is leaking, time to replace (or fix) another one, unfortunately.
The transmission oil cooler is a separate entity , it is basically submerged in antifreeze, and it sounds like the lower tank has sprung a leak around the trans cooler line.
Maybe a radiator shop can fix it in someway at a lower cost, to avoid having to purchase a new one, especially when the rest of the rad is still like new. But being they are plastic and a bit more unforgiving than the radiators of the past, the repair idea is a slim one.
A still runnin' 01 Limited,,all with a little prayer, and a lotta elbow grease
Red tint tails, chrome trimmed grille, custom towel rack buttonless flamed shifter, auto dimming rear view, Homelink remote transmitter, driver seat drawer, MOPAR sub, lowered 1" rear, MOPAR/Borla dual tipped exhaust, chrome trimmed GT gauge/airbag surround, front 35% tint, and the ever so important Fuzzy Dice
Old 27 Mar 2013, 07:48 am
What you have is a coolant leak around the fitting of the trans cooler. The OEM has a wide flat nut that you tighten just like a bolt. If it's hex shaped, try tightening it.
Old 27 Mar 2013, 07:18 pm
Thanks for both replies. I figure I'm going to have to remove it regardless of repair or replacement, so I'll remove it tonight and see what I've got. I'll let you know what I find out.
Old 29 Mar 2013, 10:16 pm
After removing the radiator last night, I found both halves of the thin hex nut Busted PT referred to in the reply. The nut was apparently defective and had split in half! I found it laying in the stamped metal pan that the radiator sits in. Now I'm on a "hunt" to find a replacement nut. Thanks again for your help.
Busted_PT likes this.
Old 30 Mar 2013, 02:24 am
Exclamation Re: Coolant leak at transmission line
Good to see your on the mend. Try the fasteners stores. The may be able to help. Keep us posted. And your welcome on the help.
Oil feed line leak to turbo PTCruisinTurbo General Turbo Discussions 1 30 Dec 2013 01:31 pm
Troubleshoot coolant leak: Photo of Coolant on top of engine radiator cap MarcusO Tech & Performance Forum 7 27 Apr 2013 09:16 am
pin hole leak at turbo's coolant line pppt03turbo General Turbo Discussions 1 21 Aug 2009 12:08 pm
Oil Cooler Line leak dpj450 General Turbo Discussions 1 24 Jul 2006 03:50 pm
Leaking coolant line TripleJackInGA General Turbo Discussions 0 03 Oct 2003 10:00 pm
