Old Timing belt?
Old 28 Mar 2013, 09:46 pm
Default Old Timing belt?
Car has 159k is this normal timing belt wear? I don't know if it was ever changed.
Old 28 Mar 2013, 09:52 pm
cruserdad1976's Avatar
Default Re: Old Timing belt?
well at 159 im gonna say its not original that might be a record
Old 29 Mar 2013, 08:16 am
Actually I have seen a few cases of this milage. But either way this is rubbing something on its back side of the belt. I would make hast and plan the change of this belt. Lots of help here to read to do this yourself.
Old 29 Mar 2013, 02:24 pm
is trimming belt is this belt witch is on the right side of the car near the front tire? I heard today strange sound coming from belt...i guess i need to change it i have just 67000 for pt06
Old 29 Mar 2013, 02:38 pm
So are the other belts. Could be just one of them. They usually don't make a noise unless there coming apart. Which is rare.But you need to address this problem asap.
Old 29 Mar 2013, 04:24 pm
holy crap! my timing belt was in better condition than that AFTER it snapped.
Old 29 Mar 2013, 04:46 pm
if it was changed on time it should look better tan how it does now, weird
Old 30 Mar 2013, 02:59 am
I agree with Busted. Also, it could be the idler pulley or the tensioner pulley dragging. If you removed the plastic cover that you spread apart, there might be a worn spot showing. And, you would get a better view of the timing belt.
Timing belt shield, belt replacement. jdwalk04 Tech & Performance Forum 13 14 May 2012 10:01 am
Belt change help - Not timing belt skfloyd Tech & Performance Forum 2 23 Apr 2010 11:23 am
timing belt greg55 Tech & Performance Forum 1 08 Mar 2010 09:19 pm
