No Start
Old 01 Apr 2013, 07:27 am
Default No Start
hey chromenut got a problem with my pt. here it is. I started my pt yesterday and after a minute in park it started raping (at first I thought:blush it was garage door) for about 2 minutes then shut down. it wont restart. I checked timing belt, that was in tacked so replace coil still nothing and don't have a spark. have any suggestions on what it sounds like. tried the code and it flashes 10 times.?????
Old 01 Apr 2013, 09:06 am
Default Re: No Start
Moved you over to your own posting instead of attaching it to an ongoing trouble code thread.
Try replacing the Camshaft Sensor. That tells the computer to send the spark. Many owners have had to replace it. When and if you do, only use a genuine MOPAR replacement sensor. Our PT's don't like aftermarket electrical parts.
The trouble code trick works every time if done right. Turn the key 3 times back and forth within 5 seconds and either you get a fault code or it will say "done".
How to retrieve fault codes.
Troubleshooting Error Codes Chromenut General PT Cruiser Discussions 6 03 Apr 2019 07:23 pm
Troubleshooting PT Cruiser Error Codes Chromenut Tech & Performance Forum 21 02 Mar 2019 10:11 am
05 PT Cruiser Error Codes & Idles high GA81PEACH19 Tech & Performance Forum 5 06 May 2013 10:41 pm
Troubleshooting Error Codes Chromenut Welcome New PT Cruiser Members 3 09 Oct 2012 06:55 pm
troubleshooting help codes 340/1193 jbptcruzn Tech & Performance Forum 6 04 Jun 2011 11:29 pm
